When you select your prop, do a right click on it and you should be able to select "convert to terrain"
Terrains are useful when you want to place trees or grass for example, in order them to be placed on the right surface. I believe it's also used for paths, when you set points it goes by default on the terrain's surface.
5 Years Ago by
Walvince
