textures comes in white when importing old DAZ figures (Aiko 3 among other)
Posted By lollosone Last Year
textures comes in white when importing old DAZ figures (Aiko 3 among...
lollosone
lollosone
Posted Last Year
Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)
Posts: 63, Visits: 218
Finally got CC3 to work again, to find out that when I uninstalled the app trying to fix the drivers issue, I deleted all my custom imported DAZ figures. Way to go.
Started all over importing figures, and noticed that now the textures imported are white. I believe there is an easy fix, but I tried to follow all the usual suspects (including the tutorial videos) and I can't get the to work.
I did export A3 in T pose from DAZ studio; the settings used are as you see in the picture here.
https://forum.reallusion.com/uploads/images/049dc65e-e426-47f6-a538-081b.jpg
The figure has default textures, I didn't add any. Once I import in CC3 using the advanced setting and embed textures, I get the figure with correct eyes, but the head and body are pure white. Looking at the textures, there is no texture for either the head, body or eyelashes.
https://forum.reallusion.com/uploads/images/c66aacd9-06bc-4380-8c6b-0fa7.jpg
Tried to load the same FBX using simple settings and that solve the problem, but then I loose the toon textures on the figure; since it will use the CC3 realistic one.
Any idea how to fix this? I don't recall this happening with the old version of CC3. Thanks.
Posted Last Year
Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)
Last Active: 39 minutes ago
Posts: 6.9K, Visits: 14.3K
Remember that when you export from Daz as FBX you should NOT be collecting textures to a folder.  I cover this in my latest tutorial on the process.
Posted Last Year
Okay, so Aiko 3 doesn't work with the auto settings.  You'll need to create your own ini file to make this happen.
Easy enough to do and RL supplied tutorials on the process.  Let me see if I have one:
Um, can't find mine at the moment but it's easy -- just press the button to create the ini file, and edit it to put in all the Aiko textures.  I think the RL manual also covers this so if you can't find it let me know (I'm busy with something else right at the moment).
Last Year by Kelleytoons
Posted Last Year
Okay, this tutorial talks about a lot of things but around the 4 minute mark it shows what you need to do to fix this issue:
lollosone
lollosone
Posted Last Year
Thanks a lot Mike!
Indeed before posting I did my homework and tried the different tutorials out there. I could swear that I was able to get the textures right at the first try, with old versions of CC3.
I will try to modify the file as you explained in your video; and see if that fix things. In the worst case I can probably use one of the toon character skin presets that came with the toon pack for CC3 (bought that since I needed pronto some cartoon figures), which should work fine for A3 too.
