OK, so you asked and I did it. But here are few points:
1. The model you gave me a link for is not the same as pictured. It has a different bones structure. So looking at my video would most likely not help to convert the original model you are working with.
2. I do not usually talk in my videos. In this case narration is a must. But I still do not talk. So take it as is..
3. To actually do it right way, including facial expressions and properly setting right T-pose takes hours. I hate setting T-pose in 3DX anyway. My 5 min video is quick and dirty only for the minimum required bones.
4. This is Xnalara model. It has to go through Blender first for the precise T-pose, materials and mesh fixing. Basically a day of work at minimum.
5. You are not that stupid as you said if you got thus far
6. Only doing it yourself with trial and errors would help you in most of the cases when converting models. You learn by doing.
7. There probably whole bunch of better videos out there for converting to non-standard. So someone might post yet more....
5 Years Ago by
