jef.goris2
jef.goris2
Visits: 370
When I want to link or attach a CUSTOM prop, like a hat, to a character, I clone 7 tells me that it isn't possible. Is there a way to attach or link a hat to a character that walks along a path ?
Last Active: 10 hours ago
Posts: 15.7K,
Visits: 30.5K
What exactly are the steps you try to do this, because it should be straightforward. You select the prop and then in the Modify panel there are options to Link or Attach. Select one or the other and the cursor will turn into a selection marker (don't know how to call it). With the marker you then click on the appropriate area of the character in the view port. So for a hat it would be the head.
jef.goris2
jef.goris2
Visits: 370
Hello, you're absolutely wright and everything you say is wright as long as you use a PROP from TEMPLATE. When you use a prop that you made by yourself, like a hat, you select it, than you got that little quare and position it above the face of the character and enter, it won't work. I clone 7 don't let you attach or link props which you made by yourself. (I mean CUSTOM props) At least this is my experience but i am a beginner.
Last Active: 21 minutes ago
Posts: 9.1K,
Are you sure they are props and not, for example, clothing? How exactly did you make them? (Give us the step by step process).
jef.goris2
jef.goris2
Visits: 370
I made a hat in BLENDER, than exported in FBX, imported in 3 D X CHANGE, and from there I send it to I Clone 7 as a prop. After I read your comment I did everything over new, and i can ATTACH the hat to a part of my character, it's a CC STANDARD character with a new body from one of the 100 RL Head serie. I have the possibility to attach the hat to the Root bone, or to the eye, I don't have the possibility to attach the hat to the head. When i let my character walk along a path wit an EZ motion walk the hat don't follow the character. What do I do wrong ?
Posts: 15.7K,
Visits: 30.5K
I don't have iClone open right now so this is from memory. In the Modify section where you Attach or Link where you see name of the bone listed, there is a button with three dots. Click that and you will see the full bone hierarchy where you can select the head. I would suggest to check the manual for details.
jef.goris2
jef.goris2
Visits: 370
Hey, You solved my problem ! Thanks a lot. I was already thinking when you use the Edit Motion Layer you see all the bones of the character. But I couldn't find where i could find them, untill you solved it. I linked the hat to the head bone and now the hat follows nicely the character, and now I can also link a bag to the right hand of my character. Again, thanks for helping me. ( It's not so easy for me, i am 71 and English is nog my native language)
esemgee
esemgee
Visits: 469
@animagic. Like an idiot I am trying to have a character play guitar. I am using moves and guitar from Rock band. And here lies the problem - the body of a guitar is sort of static, but the neck can 'move' up and down, forward and back, etc from the body's central point. How can that be done in iClone? If I link the fretboard to the hand then the body goes mad, or the body to waist, then the neck is miles from the hand. I had hoped I could attach the hand to the fretboard but I get an error message, says I can't attach something to itself. I think that is a clue, if hands can attach to props then is this guitar a prop? How do I find out? Somewhere there is a tutorial on a person using a spear or staff that has similar moves - one arm is different to another, though not as dramatic motions. There is little help from the pages of Rockband - just the obvious 'learn to animate', but I am sure there must have been a method in the creator's mind as it is an extremely complex piece of animation for anybody.
thebiz.movies
thebiz.movies
Posts: 2.0K,
Visits: 41.1K
Heres a quick tutorial I made on the subject. Short version is too make sure the guityar/bass is attached to the hip bone and adjust as needed to the animation. Then use a reach target for the fretboard hand to move the hand along the frets as she plays. Hope it helps.
4 Years Ago by
thebiz.movies
esemgee
esemgee
Visits: 469
@thebiz. Perfect! After posting my question I had a distinct memory of maybe dummies being used and you have certainly pointed me in the right direction and the problems of hierarchies (I watched Warlord's video after yours) I am baffled why my searches never found either video . Love the anime characters - new to me! Will try tomorrow, but I think you have 100% solved my problem. Many thanks
