Here is a code to show the issue I'm having. To test it, you want to put some image named "image.jpg" to the same folder as the script, it will be used as texture.
import os, time, math, random, RLPy, PySide2, copy
from winreg import *
from PySide2 import *
from PySide2.QtWidgets import *
from PySide2.QtQuickWidgets import QQuickWidget
from PySide2.QtQuick import QQuickView
from PySide2.QtCore import QUrl
from PySide2.QtCore import QObject
from PySide2.shiboken2 import wrapInstance
cwd = os.path.dirname(os.path.realpath(__file__))
Registry = ConnectRegistry(None, HKEY_LOCAL_MACHINE)
RawKey = OpenKey(Registry, r"SOFTWARE\Reallusion\iClone\7.0")
ic_template_path = os.path.abspath(QueryValueEx(RawKey, "Template Data" )[0])
def findObj(name, type = RLPy.EObjectType_Prop):
obj = RLPy.RScene.FindObject(type, name)
if obj == None:
print("object '{}' is not found on the scene".format(name))
return obj
def loadObj(path):
global ic_template_path
full_path = ic_template_path + path
status = RLPy.RFileIO.LoadFile(full_path)
if status != RLPy.RStatus.Success:
print("object '{}' is not found".format(full_path))
return 0
return 1
def getControl(obj, name):
control = obj.GetControl(name)
if control == None:
print("control '{}' for object '{}' is not found".format(name, obj))
return control
def setTexture(mat_comp, mesh_name, mat_name, channel, file):
global cwd
full_path = cwd + file
result = mat_comp.LoadImageToTexture(mesh_name, mat_name, channel, full_path)
if result != RLPy.RStatus.Success:
print("LoadTexture '{}' failed".format(full_path))
class Prop():
def __init__(self, name, path):
self.name = name
self.path = path
self.key = RLPy.RKey()
self.key.SetTime(RLPy.RTime(0))
self.obj = None
self.tsc = None
self.dbl = None
def link(self):
self.obj = findObj(self.name)
mesh_list = self.obj.GetMeshNames()
self.mesh_name = mesh_list[0]
self.mat_comp = self.obj.GetMaterialComponent()
mat_list = self.mat_comp.GetMaterialNames(self.mesh_name)
self.mat_name = mat_list[0]
def setup(self):
if self.obj != None:
self.tsc = getControl(self.obj, "Transform")
if self.tsc != None:
self.dbl = self.tsc.GetDataBlock()
def texturise(self):
setTexture(self.mat_comp, self.mesh_name, self.mat_name, \
RLPy.EMaterialTextureChannel_Diffuse, "\\image.jpg")
RLPy.EMaterialTextureChannel_DiffuseBlend, "\\image.jpg")
RLPy.EMaterialTextureChannel_Glow, "\\image.jpg")
def load(self):
if loadObj(self.path):
self.link()
self.setup()
self.texturise()
prop = None
def create(event):
global prop
prop = Prop("Box_001", "\\iClone Template\\Props\\3D Blocks\\Box_001.iProp")
prop.load()
def test(event):
global prop
prop.mat_comp.AddTextureWeightKey(prop.key, prop.mesh_name, prop.mat_name, RLPy.EMaterialTextureChannel_Diffuse, 0.92)
prop.mat_comp.AddTextureWeightKey(prop.key, prop.mesh_name, prop.mat_name, RLPy.EMaterialTextureChannel_Glow, 0.23)
prop.mat_comp.AddTextureWeightKey(prop.key, prop.mesh_name, prop.mat_name, RLPy.EMaterialTextureChannel_DiffuseBlend, 0.46)
def test2(event):
global prop
rl_dialog = RLPy.RUi.CreateRDialog()
rl_dialog.SetWindowTitle("Dialog")
pyside_dialog = wrapInstance(int(rl_dialog.GetWindow()), QtWidgets.QDialog)
pyside_layout = pyside_dialog.layout()
def addButton(title):
global pyside_layout
widget_button = QtWidgets.QPushButton(title)
pyside_layout.addWidget(widget_button)
return widget_button
button_start = addButton("CREATE")
button_test = addButton("TEST")
button_test2 = addButton("TEST2")
button_start.mousePressEvent = create
button_test.mousePressEvent = test
button_test2.mousePressEvent = test2
rl_dialog.Show()
First, you press "CREATE" to make a textured cube with Diffuse, Blend and Glow channels.
The problem is with the function test (assigned to button "TEST").
def test(event):
global prop
For some reason, only the last channel will change its weight, in this case Blend. If you shuffle the order, whichever is the last one will change weight and others won't.
On the other hand, if you only have one call to AddTextureWeightKey as in the function test2 (assigned to button "TEST2"), it will always work.
So, if you press CREATE and then TEST, Diffuse channel will not change weight, if you then press TEST2 - it will.
aCuteMissFortune
5 Years Ago by
alikims
