Posts: 5.0K,
Visits: 15.9K
Some of the quaternion bugs are fixed. But bone.localTransform() is still buggy. I also found a new bug in BoneTransformControl.SetValue(). You can only set one bone at a time. So we need to wait some more until we get those fixed. OK, no problem. We'll wait.
The-any-Key
The-any-Key
Visits: 1.9K
toystorylab (7/26/2019)
Started working further on this and keyframes still don't drop on my cursor position Works fine here. Can you give an example how your workflow is?
The-any-Key
The-any-Key
Visits: 1.9K
TBone50 (7/25/2019) does this work with characters?Yep:
toystorylab
toystorylab
Posts: 4.4K,
Visits: 28.8K
toystorylab
toystorylab
Posts: 4.4K,
Visits: 28.8K
I still have no clue why it behaves so strange on my pc, but here is my first result:
The-any-Key
The-any-Key
Visits: 1.9K
toystorylab (7/27/2019)
The-any-Key (7/27/2019)
Started working further on this and keyframes still don't drop on my cursor position Works fine here. Can you give an example how your workflow is? Wow, that's stunning... I don't get this accurate behaviour and keyframes flip further in the timeline.
Took me a while to get this gif... Never done before, used premiere. How do you make your gifs? Found the time issue and it is now fixed. Version 1.4 is now out: Bigger bone window Save and load groups Fix key time issue
toystorylab
toystorylab
Posts: 4.4K,
Visits: 28.8K
The-any-Key (7/27/2019) Found the time issue and it is now fixed.
Version 1.4 is now out: Bigger bone window Save and load groups Fix key time issueHm, it does not show up in iClone... I see it loading (super Bone Editor) in the opening screen but it's not there. As the content of the exe is very different to 1.3: Do i have tu unzip all these files? I simply put the whole folder in "OpenPlugin" as i did with 1.3...
toystorylab
toystorylab
Posts: 4.4K,
Visits: 28.8K
Sorry, it appears... BUT only when i start iClone as administrator. In version 1.3, i only had tu run as administrator once...
The-any-Key
The-any-Key
Visits: 1.9K
toystorylab (7/28/2019) Sorry, it appears... BUT only when i start iClone as administrator. In version 1.3, i only had tu run as administrator once...
When you update you should run it in admin mode once. The plugin might ask you that Python need write access to the site-packages folder in iClone (as some new modules use cache folders there). So after you run it once or twice you should be able to start it in non-admin mode.
toystorylab
toystorylab
Posts: 4.4K,
Visits: 28.8K
