Last Active: 35 minutes ago
Posts: 9.1K,
While I'd rather not share this avatar (but will if I must) I am having a weird problem and I thought one of the experts could comment on it. I brought in a 3DMax FBX file into 3DX and while it's not perfect I was able to get it rigged so it will work as a non-standard character. In iClone it will accept regular motion files just fine and otherwise behaves like any other non-standard character I've used (or even a standard avatar, except I obviously can't send it to CC3). However, I can't attach or link anything to it. Doesn't matter what it is -- even a simple sphere -- and in the same exact scene (brand new) I can attach to any other avatar, regular or non-standard. But this one just seems... invisible to the pick parent button (which is to say I press the button and get the pointer but can't click anywhere on that avatar -- it acts as if it isn't in the scene at all). Has anyone ever seen anything like this? Is there something I'm doing wrong? I can't even imagine how this could NOT work -- I understand attach and link only work for avatars but iClone sees this as an avatar for the purpose of using motion files, so it's hard for me to believe it's somehow not any other way (and no weird names or anything).
Last Active: 51 minutes ago
Posts: 15.7K,
Visits: 30.5K
Everyone seems baffled... I don't believe I have ever encountered this, so I can't be of much help. The only thing I could think of would that there is something wrong with the pivot. If you select the character is it properly enclosed by a yellow box?
Posts: 9.1K,
Yeah, I thought about that as well -- and the bounding box seems fine. I wish there was a python way to try and attach because I could see if I could get around it that way. I may send this to RL support just to see what they can make of it. When I activate collision shapes they are a bit weird -- within the body, but sized a bit oddly (by default, at least). However, they seem to work so it's only the fact I can't attach anything to it that makes it *really* odd. I guess I should be happy that it's not my ignorance here -- there are MANY things about iClone I'm pretty stupid about, but it doesn't appear this is one of them.
Posts: 5.0K,
Visits: 15.9K
I think you have a case of flipped normals on avatar. When bounding with + appears (after clicking attach), try to select avatar in Scene manager. It would attach to the Bone Root. Then you may pick a right bone from the list.
5 Years Ago by
Posts: 9.1K,
Oooo, flipped normals sounds right. I definitely had issues with the faces (and had to flip a lot of them in 3DX). Hmmm, I wonder if there's anyway to unify them in 3DX. Bingo! Ah, see, there IS something I didn't know, that you could attach things by picking them from the scene list. Thanks, Mr. G. I wish you had responded just FIVE minutes ago (I sent the file to support and I suspect they'll tell me the same thing). I wonder if the normals being flipped have something to do with the other issue I have with this avatar -- the arms act "reversed" (not the feet nor the rest of the body). I can work around it by editing the motion layer at the start of the animation, but nothing else I try works (including rigging it the other way around for the arms).
Posts: 5.0K,
Visits: 15.9K
I've read it yesterday, but only this morning all of the sudden I recalled I had similar problem with a prop and it was a case of normals, where the picker did not see the back face. Try flipping faces in 3DX (I never used it though).
5 Years Ago by
mark
Last Active: 10 hours ago
Posts: 4.8K,
Visits: 16.4K
Brilliant catch 4u2!!!
Posts: 9.1K,
4u2ges (5/30/2019) I've read it yesterday, but only this morning all of the sudden I recalled I had similar problem with a prop and it was a case of normals, where the picker did not see the back face. Try flipping faces in 3DX (I never used it though).
No, I had to flip faces in 3DX just to get them to show. However, I've done this in the past and it never stopped the avatar from having normals flipped on all parts of it (even the parts I didn't flip couldn't be selected). There is a "unify" but it doesn't do anything that I can tell, and using Flip on the whole figure doesn't help. What I guess is needed is some sort of "correct normals". But no matter -- it's good that it's solved. Thanks again!
