Why does Preview never have any Shadow Artifacts?
Posted By Strife 5 Years Ago
Strife
Strife
Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)
Posts: 11, Visits: 393
Anyone know why the Preview mode with iRay render never seems to show any artifacts - shadows look great... but then when you do an actual render (with Eliminate Shadow Artifact ON) the artifacts show up consistently?
Is there a setting Preview has enabled that we can match in the final render settings?
Posts: 15.7K, Visits: 30.5K
It might be helpful if you post images of Preview and render. Otherwise it's hard to determine what's going on.
3dtester
3dtester
Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)
Posts: 995, Visits: 2.2K
I experience the same issue, ever since i'm using Iray in iClone.
The shadows in the final MI render often don't look smooth.
They have hard edges and sometimes also 'artifacts'.
In preview mode, the shadows always look good.
I have too posted a thread about this a while ago, but never got any replies...
https://forum.reallusion.com/402039/iray-shadow-hardness
https://forum.reallusion.com/uploads/images/ba9e0376-e995-4328-aaa6-d777.png
I never found a way to fix these shadows in iClone.
5 Years Ago by 3dtester
It's been a while, but as I recall the size of the light sources influences the quality of the shadows in Iray.
For every light sources used you can change the size in the Iray settings and this will change the sharpness or softness of the shadows.
Posts: 5.0K, Visits: 15.9K
First, there are some issues with MI render compare to Preview, but I have never experienced any issues with shadows. Screenshots please?
Second, Animagic is correct. Shadows softness depends on light source shape and it can be tweaked in Lights tab of Iray settings.
Finally, when it comes to purely IBL light, there is no way to control shadows other than tweaking the IBL image itself (or transforming it).
Yes, IBL does not cast shadows in iClone, but physically accurate Iray would cast shadows from any source including IBL.
@3dtester IBL normally produces very soft shadows with Iray. That makes me wonder what kind of IBL image you used to have such harsh shadows?
Also can you look at the Lights tab in Iray settings to see if there is nothing else listed as a light source?
I can't get anything sharper than this with IBL (which is fairly soft IMO):
https://forum.reallusion.com/uploads/images/1334f1c0-9d20-4484-9407-b4cc.jpg
5 Years Ago by 4u2ges
3dtester
3dtester
Well, you are right, i used an additional light for that scene. But only because Iclone IBL doesn't cast shadows.
I should have checked the Iray settings for that light source...
But i have a small example from a recent render test (IBL only).
The images are cropped to the neccessary section Wink
Preview render:
https://forum.reallusion.com/uploads/images/696af74a-4e7a-4488-a308-01be.png
MI render:
https://forum.reallusion.com/uploads/images/11a5a283-5463-46f1-a470-1122.png
Oh wow! Let me check...
Yep, appears to be a bug. The attribute string "shadow_terminator_offset_mode" "on" is present in the MI export.
However, it seems to be OFF regardless. And I am afraid it is one of those NVIDIA bugs cases.
Another example:
https://forum.reallusion.com/uploads/images/a7bbac7f-4256-4ad6-946a-e91d.jpg
https://forum.reallusion.com/uploads/images/edf2cba8-ae8a-4cc7-a79b-8f87.jpg
You guys may want to open an FT issue. Otherwise I'll try to do it later on.
I just want to stress how important it is to report such problems to RL in the Feedback tracker.
We might have gotten some answers from RL 3 month ago.
Found temporary solution. Apparently one other attribute is missing in the MI export (for the case when "Eliminate Shadow Artifacts" is checked):
attribute boolean "shadow_terminator_offset" true
Inserting this attribute into scene options section of the MI export fixes the problem. This is definitely an RL bug.
https://forum.reallusion.com/uploads/images/c1bef7a2-1d04-44e8-8981-1d63.jpg
UPDATE: FT 6162   "Eliminate Shadow Artifact" does not work with MI Export
3dtester
3dtester
Thanks a lot for taking care of that issue, 4u2ges.
I hope RL will fix it in the next update (without waiting for enough votes...)
