rcsinger29
rcsinger29
Last Active: 8 days ago
Visits: 3.0K
Hi guys, Long time no talk. I am experiencing an issue with textures not displaying correctly when using transformer utility to import DAZ items. Specifically hair. The texture maps load and display correctly in CC3. But when exported into iClone, the avatar hair is shaded with no texture. The maps are present and loaded, but they do not display. If I reload the maps. The response is “wonky”, then I can click undo and everything is fixed.
Last Active: 58 minutes ago
You need to subscribe to my channel <g>. (The quick answer -- change to accessory, and then back to hair).
5 Years Ago by
Galfridus
Galfridus
Visits: 2.2K
Thank you very much Mike. Your response to the OP solved a similar problem I was having with Daz Duarte Hair. This seemed to work in CC3 but texture issues when exported to IC7 including crashing. (change to accessory, and then back to hair) in CC3 was the fix I couldn`t discover for myself. Your "work around" has been much appreciated by this user. Geoff.
You're very welcome. I try and share whatever I find in the hopes it will save others the pain (and then they do vice versa, so we all win :> .
rcsinger29
rcsinger29
Visits: 3.0K
Awesome, Thank you so much. Such a simple fix.
