Hi
I'm having a spot of trouble with this Theate that i bought from renderosity. The 2nd picture is the problem.
As you can see, the problem is the walls and balcony. I want to put a texture in the diffuse map of something similar to tthe 1st picture. Maybe even just a dark wood, but because of the lines or mesh, it comes out messed up. You can see on the 2nd picture, the lines on the wall that's preventing it looking good.
The guy i bought it from never supplied the textures and won't reply to anyone on renderosity so its time consuming and a pain getting it to look like the original picture. I've tried adjusting the tiling but nothing seems to work. Is there any way to get rid of the lines so that i can simply apply a texture and it will look like the texture im applying.
Thanks in advance.
