Path does crazy wandering at the beginning then works properly. How can I fix it?
Posted By AncientWire 5 Years Ago
Path does crazy wandering at the beginning then works properly. How...
AncientWire
AncientWire
Last Active: 4 days ago
Posts: 62, Visits: 886
I created a path to walk my character through a labyrinth.  It was created all at once with me placing points in the correct order from beginning to end.
At the Start (Red point not shown, but off to the bottom) My character does a wobbly spinning dance then proceeds on.  I moved the start point off of the screen to avoid it showing, but a fix would be better.  I tried moving her around a bit in relation to the beginning point, but I had no success in making a smooth start.
The worst bit is first 9 points which have arcing movements which I did not intentionally create.  The whole labyrinth should look the same as from point 10 to the end (Blue).  All of the points are on the ground and level with each other.
So, why does the path do the funny looping swirling thing, how can I fix it, and when I go to edit points the path disappears so I can't really tell what is happening anyway.
Thank you!
Helene
https://forum.reallusion.com/uploads/images/f2842229-ce0b-46a4-a238-cc9d.jpg
3dtester
3dtester
Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)
Posts: 995, Visits: 2.2K
Hi, i just saw this and the question came to my mind:
Did you check 'project to terrain'? If not, the path may go up and down (this happened to me a few times).
If you don't see the path when you click it, it may be off the ground. Or, is it toggled invisible so you only see it when the character is selected?
Just simple guesses and i may be completely wrong...
Last Active: 4 hours ago
Posts: 8.1K, Visits: 60.6K
That's a bug I have seen. You put it in the feedback tracker. Include a video of what it's doing.
https://www.reallusion.com/feedbacktracker/
AncientWire
AncientWire
Thank you.
I put it in the feedback tracker.
/wave
