The-any-Key
The-any-Key
Visits: 1.9K
With this plugin you can record movements with your mouse, keyboard and joystick and apply the recording to cameras and props. It got some basic features like wiggle and orbit.
Trial: https://marketplace.reallusion.com/move-that-camera
The-any-Key
The-any-Key
Visits: 1.9K
Update 1.4: Flight mode, quaternions to avoid gimbal lock, apply only specific parts of a recording.
3dtester
3dtester
Visits: 2.2K
For some reason, the plugin doesn't work as expected here. I am using iClone 7.6 and already had the 'time transformers' plugin, which works.
The problem is, the camera or prop doesn't move at all. I tried to map different controls (gamepad, keyboard, mouse), but no success.
Additionally, iClone crashed two times since the plugin was installed.
The-any-Key
The-any-Key
Visits: 1.9K
3dtester (9/1/2019) For some reason, the plugin doesn't work as expected here. I am using iClone 7.6 and already had the 'time transformers' plugin, which works.
I will run some tests, can be something new in 7.6
3dtester
3dtester
Visits: 2.2K
Thanks, i watched the tutorial a few times. So, from what i have tried, i should at least have seen some movement. It didn't even work with a simple sphere prop,
Posts: 5.7K,
Visits: 26.4K
Try the advice given in this post: https://forum.reallusion.com/FindPost420813.aspx
3dtester
3dtester
Visits: 2.2K
Oh it's magic! Unchecking the 'reduce idle load' option makes the plugin come to life
The-any-Key
The-any-Key
Visits: 1.9K
Ahh, hopefully we will be able to detect this in the API in a future update so we can give the user a message about it.
The-any-Key
The-any-Key
Visits: 1.9K
Version 1.5 is now live: Gravity settings Apply recording progress Save and Load remember last folder
3dtester
3dtester
Visits: 2.2K
Since i installed the 1.5 update, the plugin doesn't show up in iClone anymore.
I extracted the files in the plugin folder, overwriting the old files. Then i started iClone in administrator mode a few times. It must have installed a dozen additional Python modules. Is this normal?
However, finally it has disappeared from the plugin menu.
Also, the Time Transformers plugin doesn't work anymore. Maybe the trial period is over?
Thanks, 3dtester
