Hi,
Never had this issue before version 7.
I load up a character (CC), add a simple stock animation to it, then want to break the animation at a point to remove the ending. What happens is that a section either before, or after, or before-and-after the break is suddenly filled-up with key frames. It only happens when I break the clip NOT standing on an existing key frame. Obviously the way to workaround this is to create a key frame on the frame where I want to break, break and then remove any excess key frames.
Is this intended functionality or a bug?
I've added two screen shots. One before breaking the clip and one after.
Cheers,
Marco
Running iClone Pipeline 7.41.2525.1
