When breaking an animation clip, every frame becomes a key frame
Posted By Dutchottie 5 Years Ago
Dutchottie
Dutchottie
Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)
Posts: 11, Visits: 190
Hi,
Never had this issue before version 7.
I load up a character (CC), add a simple stock animation to it, then want to break the animation at a point to remove the ending. What happens is that a section either before, or after, or before-and-after the break is suddenly filled-up with key frames. It only happens when I break the clip NOT standing on an existing key frame. Obviously the way to workaround this is to create a key frame on the frame where I want to break, break and then remove any excess key frames.
Is this intended functionality or a bug?
I've added two screen shots. One before breaking the clip and one after.
Cheers,
Marco
Running iClone Pipeline 7.41.2525.1
Posts: 15.7K, Visits: 30.5K
To avoid that place a Motion Layer key frame before and after the intended break point and then apply the Break.
