Yay, finally got my new computer yesterday and now I can't believe how much better iClone and CC is working for me. Loads quick and it shows contents really quick now. My old computer was high level too but I setup the drives in raid mode and this one isn't. I wonder it that caused slowness? Anyway I will get to the point on this post now.
At least as far as I am aware, how well clothes will attach to different characters depends a lot on how much the clothes follow the shape of the characters body.
For example the inner sleeve on this outfit was made to the same shape of the characters arm.
However the character I made it on is thinner than the base male character so loading it to that character ends up like this. It follows the arms shape well but is penetrating the arm because the arm is thicker.
The easy way to fix that is to go into conform mode and conform it so it fits...really easy and here is how
If its still not how you want you can go into edit mode and make it bigger or smaller. Again, really easy doing it like this.
These are all pretty easy because the clothes pretty much follow the characters body so when you load it onto a different shaped character it still follows the characters shape pretty well and still looks fine. Might need to make some slight changes but nothing too difficult.
Now onto the problem your having. Here the outfits do not fully follow the shape of the characters body. For example the outer part of the cloth just flows straight down from the characters chest and doesn't follow the shape of the character much. Unfortunately what happens is when you load it onto a character with a big difference in shape CC makes the cloths totally follow the characters shape and that is why your getting what you have. If you look at the characters body you will see the shape of the clothing is following that now. CC gives everyone the ability to go into edit mode and adjust that and I find it pretty easy to do that
Here is an image showing one of the main things I use and also showing how I got it adjusted within 30 minutes. There are plenty of other methods and reallusion has video tutorials showing those capabilities so not including them here
And here it is finished
The thing is, if I save this I can reload it onto this particular character and it will fit just like this. But if I load it onto a fat character then or a lady then there are going to be some things that need adjusting again.
I find these adjustments pretty easy to do....a little confusing having too but not too difficult. But I am starting to think maybe I find it easy because I am into modelling.
So I am going to set these outfits up now for thin, base and fat males and females and I will add them to my store prop for this outfit and let everyone who has bought it know that they can redownload it to get the extra sizes that will make it easier for people to add then to different shape characters. They may still be some smaller adjustments that need to be done but this should make it easier for people who find it difficult.....I hope.
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
