cc3 character is too big for outfit
Posted By Kimmie777 5 Years Ago
Kimmie777
Kimmie777
Distinguished Member (4.2K reputation)Distinguished Member (4.2K reputation)Distinguished Member (4.2K reputation)Distinguished Member (4.2K reputation)Distinguished Member (4.2K reputation)Distinguished Member (4.2K reputation)Distinguished Member (4.2K reputation)Distinguished Member (4.2K reputation)Distinguished Member (4.2K reputation)
Posts: 569, Visits: 1.1K
Can someone please walk me through how to fix this, please?  The outfit is too tight on him.
The coat needs to flow around him and his skin is busting out of the attached robe underneath the coat.
Thanks!
~ Kimmie
www.TrackingJESUS.net
--> More Information On This Bible Film Production Can Be Found At:
www.TrackingJESUS.net/Productions
--> Become An Early Subscriber To The 'Tracking JESUS' YouTube Channel At:
https://www.youtube.com/channel/UCEMx91AySc3QuF-SS_3mGQQ
cc3 character too big for outfit.jpg (73 views, 108.00 KB)
gordryd
gordryd
Posts: 711, Visits: 7.6K
Inside CC3, select the offending clothing article in the 'Scene' tab, then click on 'Conform' along the top CC3 menu bar.  Usually clicking on 'Calculate Collision' will fix minor issue, otherwise you might have to play with making the garment larger/looser with the controls on that tab.
Kimmie777
Kimmie777
OK, it got rid of the skin coming through.  But it seems to think that the "loose" bar is only for a small strip along his chest.  It does not affect 99% of his outfit.  I have it at the highest on "5".
Thoughts, please?
Thank you, Gordon!
~ Kimmie
Last Active: 17 minutes ago
Posts: 8.1K, Visits: 60.5K
For a small pass through like that, just hit the conform without adjusting the smoothness/looseness setting. There is a scale slider in the conform tool. You can increment it slightly to make the clothes a touch larger.
Kimmie777
Kimmie777
How do I specifically make the outfit so it is not so tight / form-fitting around his rib cage and hips?
https://forum.reallusion.com/uploads/images/748615ad-9c2d-4e93-8d06-6c67.jpg
kenshinw95
kenshinw95
Posts: 42, Visits: 135
increasing the "margin" may help out. From my past experiments with Character Creator 2 & 3, that option seems to control a "cushion" between your character, and the clothing.
Kimmie777
Kimmie777
I now have the margin maxed out at 3 and the loose fitting maxed out at 5.
Clicking conform and then clicking calculate collision only fixed his chest busting through the outfit.  It did not fix anything else.
Clicking that more than once makes the problems much worse.
So aside from margin and loose fitting (which did not look like either did anything at all), what else can I do?
(Thanks, you guys. :-) )
~ Kimmie
https://forum.reallusion.com/uploads/images/f34a1104-3cf1-48c2-bd72-8ff4.jpg
The scale up at the top "Increase Size" will enlarge the garment along its normals, thus making a looser fit.
Here is the Help page on using the conform tool. It will probably make using it more clear:
http://manual.reallusion.com/Character_Creator_3/ENU/3/Content/Character_Creator_3/3/08_Cloth/Conforming_Clothing.htm
I think there is a typo in the UI. The "Loose fit" your using is actually "Close fit" in the manual. I'll inquire with the team on this, as it seems a bit confusing.
Kimmie777
Kimmie777
Rampa, I have never seen you stumped before on anything I have run into in these programs.  This is the first time.
I did try the increase size tool and he looked really silly.  (And the outfit is still too tight / form fitted to him.)
I will paste an example here for you below.
I am now wondering if there is anything at all inside that box of options in the modify panel that is going to fix it.
But what are we missing on options outside of the options that are in the conform panel?  I'm too new at all of this to know.
Probably only an experienced clothing creator would be able to answer this one.
I know the work is solid - Delerna made it.  And he puts great care of quality into everything he does.
Thank you on the link... I will look at it in the morning. :-)
~ Kimmie
https://forum.reallusion.com/uploads/images/0f46925f-b19e-4702-be18-aeff.png
Use the smoothing instead of the loose fitting. Try it at 5.
