Posts: 23.1K,
Visits: 36.6K
smeaton.phinehas (5/4/2019) I have same problem. I purchased CA4 pipeline with the Mocap bundle. All green lights on for face tracking and for face and body capture. But the dots around mouth and eyes aren't showing. When I try to calibrate nothing happens. What did you do to get it working. Bit of a disappointment thus far.
Try clicking the Settings button on the top right of the "Face3D Tracker" window and ensure your webcam is selected and that you have a check in the box marked "Show Marker".
kylelee
kylelee
Visits: 4.2K
smeaton.phinehas (5/4/2019) I have same problem. I purchased CA4 pipeline with the Mocap bundle. All green lights on for face tracking and for faceand body capture. But the dots around mouth and eyes aren't showing. When I try to calibrate nothing happens. What did you do to get it working. Bit of a disappointment thus far.
Hi Smeaton, You can directly contact Technical Support, I sound like this issue is not usability defect.
vidi
Posts: 10.8K,
Visits: 40.2K
My Problem is only that the Face 3D Tracker Software not will start. After many attempts, it will eventually stay open. No Idea why ?
SamPiez
SamPiez
Visits: 64
vidi
Posts: 10.8K,
Visits: 40.2K
After it did not work at all it is now really good. I think I will buy it with the mocap bundle . Makes fun ! :cool:
vidi
Posts: 10.8K,
Visits: 40.2K
Ok after some hours trying and rant, it works.:w00t: Finally the Face Tracker Window keep open after a billions attempts, I have no Idea why not before.
vidi
Posts: 10.8K,
Visits: 40.2K
I have now installed with the hub and have access to the trial again but the same, it will not work fo me The tracker thing popped on and do exit again .
Motion LIVE 2D offers the most affordable and intuitive motion capturing solution in the industry. Now you can use a regular RGB video camera or PC webcam to quickly stream and capture your facial animation data to animate 2D characters inside offers the most affordable and intuitive motion capturing solution in the industry. Now you can use a regular RGB video camera or PC webcam to quickly stream and capture your facial animation data to animate 2D characters inside Cartoon AnimatorCartoon Animator.
Sounds nice but not intuitive and quickly for me .
vidi
Posts: 10.8K,
Visits: 40.2K
I have uninstalled for a fresh install , because not working and now have now only a pay Option Sorry but without testing that it work for me I can buy :angr y:
vidi
Posts: 10.8K,
Visits: 40.2K
What do i need to work with Animator 4 Facial Mocap Feature with my Webcam ? Seems I do not understand the workflow. My Webcam is readyand all trial from hub is installed do I still need another app ? I have read the manal but not clear for me what I missing. These Face 3D tracker thing do not start, it popped on and closed imerdatly , is this normal ?:satisfied:
