Peter Blood
Peter Blood
Posts: 2.3K,
Visits: 9.4K
gordryd
gordryd
Last Active: 4 hours ago
Visits: 7.6K
Do particles have 'Visibility' toggle? If so, you could just disable 'Visibility' at that frame...
Peter Blood
Peter Blood
Posts: 2.3K,
Visits: 9.4K
You can't shut it off by using the opacity slider, I tried that. It should go off merely by switching the emit off. Thanks man, I appreciate the input.
That crazy sound came from the video I'm using on his eyes. It'll be gone in the final render.
pete
http://www.youtube.com/user/peterblood50?feature=mhee
5 Years Ago by
Peter Blood
Walt_R
Walt_R
Visits: 5.0K
Peter, It's the particle not you. I experimented and it continues to emit way after you turn it off (almost 10 seconds). Try using Legacy Particle Blaze 01 under Misc. I was able to turn it off quickly. That might help with the effect you want. Hope this helps. Walt
Warped Reality VFX
Warped Reality VFX
Visits: 8.1K
Hello, Peter, I don't know if you're using legacy particles or popcornfx but here our some suggestion that may help, the particle may stay visible for few more seconds based on the particle life and the number of particles emitted at that time. try these steps it may resolve your issue I hope this helps. 1 Deactivate the emitter. 2. Set the particle life to zero. 3. Set the emitter amount also to zero. 4. If the particle gives you access to the alpha channel set this value to zero also, in the particle, not the material section. 5. You may need to adjust the keyframes also to get the timing correct.
Warped Reality VFX.
