lollosone
lollosone
Visits: 339
A bit of background: I work mostly on Unity as developer, so my graphics skillset is limited to time and honestly, lack of interest in making meshes. I do own Character Creator 3, which I bought to import figures from DAZ mainly, into Unity and have a consistent library of figures I can create and modify easily, without spend hours in the conversion and fix issues after the conversion. So I have a somehow working pipeline from DAZ to CC3, and to Unity; although I need to animate faces now; and this is when I started to look at Crazy talk
Unity has some packages that does facial animation and text to speech; but again, it is a hassle and I don't want to waste time in trying to make it work; so I am hoping that Crazy talk is the app I may use as one stop.
My needs are simple; I may have a DAZ figure imported into CC3, I need this figure to have expression and to have audio, so it can speak and have lipsync to the audio file. Also I need to have the face to animate, either by using a recorded video of the animation, to transfer on the face, or having other means to modify and record a performance; like via webcam, iphone or what else may be useful. Once I get the face animated with the performance(s), and the audio synced to the lips, I need to export it to Unity, so I can import my figure, attach a mecanim animator and have the figure trigger the facial animation when some events happe.
How much of this can I get done with Crazy talk? As now I already have a library of characters in CC3, so what I need is everything else (record a performance/transfer a performance from a video, sync audio to lips, export to Unity and be able to trigger animations in unity).
I know that there is a demo of Crazy Talk 8; although before dig in, I want to figure out if my workflow is even feasible with this application; I may not have enough time to figure things out, since the demo just last 15 days. Thanks
The-any-Key
The-any-Key
Visits: 1.9K
I think you need to go to iClone instead and animate the face there. Tips is to use iPhoneX with Live face. Crazy talk is more for creating a 2D/3D head and make them talk. The export options are also limited in Crazy talk. You can export video, RLTalk and RLHead. But no FBX animations.
5 Years Ago by
The-any-Key
lollosone
lollosone
Visits: 339
The-any-Key (4/18/2019) I think you need to go to iClone instead and animate the face there. Tips is to use iPhoneX with Live face. Crazy talk is more for creating a 2D/3D head and make them talk. The export options are also limited in Crazy talk. You can export video, RLTalk and RLHead. But no FBX animations.Thanks, I thought that iclone was to create characters and animations; basically like DAZ studio or poser; not an application to generate facial animations. Live face is fun but it is not something that I would use at production level to be honest; it looks to me like a gimmik like the video emoji, and I am not interested in that. From what I read, Crazy talk does make talking 3d heads; which is what I am looking for; although it is not clear to me if they work, once you import them in CC3, and then into Unity; because I don't need just the head but the whole character. I remember that CT7 had a Unity plugin; although the only videos I found are from 2014 I believe; which are ancient at this point.
lollosone
lollosone
Visits: 339
So it seems that I should not spend my cash on Crazytalk at this point. Not that many replies, so that is not even a good sign, for a product that should be used by many.
I will explore other venues; for applications specifically aimed at facial animation for gaming. Thanks
