export fbx from Iclone 7
Posted By trongdung 4 Years Ago
trongdung
trongdung
Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)Junior Member (167 reputation)
Posts: 2, Visits: 12
Hi there
I'm newbie Iclone , I've try to export FBX from Iclone 7 to 3DMax17  but they alway break all mesh character in 3Dmax. There something wrong ? ( Please see attached images )https://forum.reallusion.com/uploads/images/1760ca1b-0b74-4dff-a206-747f.jpghttps://forum.reallusion.com/uploads/images/bd73b067-aeac-4bf2-87bb-9e15.jpghttps://forum.reallusion.com/uploads/images/d8906e60-60be-49a3-a16d-87e4.jpg
Distinguished Member (106.6K reputation)Distinguished Member (106.6K reputation)Distinguished Member (106.6K reputation)Distinguished Member (106.6K reputation)Distinguished Member (106.6K reputation)Distinguished Member (106.6K reputation)Distinguished Member (106.6K reputation)Distinguished Member (106.6K reputation)Distinguished Member (106.6K reputation)
Last Active: 44 minutes ago
Posts: 21.6K, Visits: 33.9K
Hi...
I just tested with the same Rock Band character and didn't have any problems as you can see below.
Did you choose the 3DS Max preset when exporting from iClone 7? And if so did you change any other settings?
https://forum.reallusion.com/uploads/images/dd0f00e0-8c70-4588-856d-ff7c.png
trongdung
trongdung
Dear Peter
Thanks for quick reply
I Thinks the master isn't in 3DMax preset, because I tried to import Iclone FBX with animation into Twinmotion 2019 and Lumion 8, but the error is the same ( Please see the attached image ) Any suggestion ishttps://forum.reallusion.com/uploads/images/004edda2-1a52-4cda-bf1f-2b35.jpghttps://forum.reallusion.com/uploads/images/a09441da-589a-4c9d-b944-90ad.jpg appreciated
Thanks for updating us.
Does the same problem occur with any character you export to FBX or is it just this particular character?
Also, do make sure that you have iClone 7 and 3DXchange 7 Pipeline updated to the latest versions. That is 7.41 for iClone and 7.4 for 3DXchange 7.
You should also make sure you have your graphics drivers are updated as these kinds of issues can often be driver related.
vicki_314
vicki_314
Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)
Last Active: 28 minutes ago
Posts: 59, Visits: 465
sorry peter, i have animator 3, and i was working on making a vector rabbit with tall ears. i put the bones on the rabbit, then wanted to change to a morph head. i watched the tutorial on how to use the mask way of changing the head. it all worked out nicely, except the yellow bones in the head and long ears turned grey and the ears wouldnt move, can you tell me where i went wrong please? i hope ive attached the file for you to check..... thanks, regards vicki    file:///C:/Users/Public/Documents/Reallusion/Custom/CrazyTalk Animator 3 Custom/Character/actors/animals/blue rabbit.ctFBactor
