Thank you for your reply Peter. Much appreciated
Point 1. I haven't reinstalled CC yetI was hoping it wasn't caused by a new content of mine that I downloaded just before I tried doing this so I deleted it from the Others folder in the templates.
I then tried loading the clothes from the templates folder and all those clothes are now loading again fine, at least the 10 or so I tried.
I have spoken to other people who also have that content and they are not having any problems with them
So I re-downloaded the contents and everything is still working fine.
I did have a problem starting CC though before I did all this. It looked to be loading for ages but then just shut down.
While it was loading I checked the task manager and saw a huge CPU usage with system interrupts
I also noticed google chrome was in the task manager with 24 items in it. While I was waiting for CC to finish loading I tried to run google too but it wouldn't start either even though it was showing up in the task manager. This sort of thing happens to me a lot. If I start CC and then try to start something else...or even if I have something else already open, click CC to start it and then go back to the thing I was reading that I had open then CC doesn't start, it just seems to be loading for a long time and eventually just shuts down. If I load CC and just leave everything alone until it finishes it loads fine, does take a couple of minutes though.
I suspect there is something to do with my computer that causes problems on CC.
I say that because I can run all sorts of programs and have no problems. But when doing it with CC and sometimes with iClone I need to stick with treating them as the only thing I am using, at least as much as possible and especially when the software is loading.
Once upon a time I used to be a big IT worker but these days computers are starting to get beyond me how to investigate what is causing problems.
I do think there is something to do with my computer that is causing the problems that I am having with CC and iClone.
I would say 70% of the time I don't have problems but it does have issues on my computer fairly regular.
I only posted this post because being unable to load the clothes from the templates folder was concerning.
But now it all seems to be working fine now.
As stated, I think something went wrong in my computer that cause these problems in CC when I downloaded the content the first time.
As stated other people downloaded it with no problem and I redownloaded it again with no problem....….so ?????
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
5 Years Ago by
Delerna
