Geoffrey James
Geoffrey James
Visits: 346
Adm ittedly, I've got plenty of CPU power (18 cores at 4GHz) but I would think that the renderer might make at least SOME use of the 2 Titan RTX hardware. NOTE: the usage that IS shown on the GPUs is from the screen capture program. When that's not running both GPUs are clocking at 1-2%. Or maybe the performance monitor isn't representing the situation correctly? Is there a switch somewhere I've missed? I'm flummoxed!
Geoffrey James Intel Core i9-9980XE 18 Cores @ 4.5GHz, 128GB @ 3000MHZ, 2 NVIDIA® TITAN RTX, 512GB SSD, 2TB SSD, 10TB HDD, 1200 Watt PS, Viewsonic 43" 4K.
5 Years Ago by
Geoffrey James
Last Active: 44 minutes ago
Posts: 5.0K,
Visits: 15.9K
The right counter to look at would be "Compute" counter, or better yet download GPUZ - very handy for monitoring Iray render.
Geoffrey James
Geoffrey James
Visits: 346
Problem solved. GPUZ shows 99% GPU usage. The Microsoft-supplied monitor is--typically--not very well programmed. Sigh.
Thanks for your help.
GPUZ is really interesting. It even tells you the nanometers of the chips in the card. Kewl.
