maya 2019 to iclone7 with 3DXchange
Posted By frederic_795268 5 Years Ago
frederic_795268
frederic_795268
Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)
Posts: 2, Visits: 13
I have maya 2019 and I'm evaluating Iclone7 to see if it can cover our needs.
I watched this video and others on the same subject but it was totally useless.
I'm surprised you don't have a topic on your documentation giving screenshots of the parameters needed in Maya to make a proper export.
The import does not look at it is described in this video for me. Should be a question of parameters but which ones ?
Maya is widely used and it worth a detailed procedure I think.
Posts: 22.7K, Visits: 35.7K
Hi...
There really isn't anything you need to do special in Maya. The default export settings are pretty much it. The rest of the work is done in 3DXchange 7 Pipeline. So if your character has a standard Maya rig then you can just choose that option when converting to a non-standard character in 3DXchange.
Please take a look at the tutorial below. It's a little old but the steps shown are still applicable and should help.
https://youtu.be/kRz1EOLgFK8
And for some documentation on the general import settings, please see the manual below.
http://manual.reallusion.com/3dxchange_7/ENU/Default.htm
frederic_795268
frederic_795268
ok... as I told in my first post, I'm using a standard auto-rigged character in Maya 2019.
When I try to use 3DXChange, it is just not working.
As I told before, I saw these videos (and a lot more) and I also had a look at the documentation.
But it seems that you have not tested your product with the last Maya version. I don't know what has changed but I can tell you it is just not working as expected.
Then what can I do now ?
Last Active: 13 minutes ago
Posts: 15.7K, Visits: 30.5K
frederic_795268 (3/29/2019)
What FBX version are you using? I believe 3DXchange requires FBX 2012.
hirospot
hirospot
Posts: 241, Visits: 5.9K
Re: Maya Model FBX test
I checked the issue by using the several free 3D models available on the Net.
The Peggy Sue at free3d.com has Maya format and rigged for animation.
The FBX version can be selected on the Maya Export option panel.(Fig1)
https://forum.reallusion.com/uploads/images/42568598-6a05-4e44-9834-5c9a.jpg
The model was converted on the 3DXchange 7 with no trouble, then the Model Face was modified here. (Fig2)
https://forum.reallusion.com/uploads/images/0289a95d-4eb3-4d53-85e7-4e55.jpg
However, this model  is the only one success and other free models were not perfect for 3DXchange.
  Ex1: Can not change the size of the model
  Ex2: Mesh and Textures are not shown
  Ex3: Not exported from Maya because of maximum polygon count exceeded (250,000 polygons)
It seems the issue is in the Maya model itself rather than Maya and FBX version.
Please be indicated the name of the 3D model under the issue.
Thank you.
5 Years Ago by hirospot
