EvilGenius
EvilGenius
Last Active: 8 hours ago
Visits: 1.1K
Ran into this issue today when bringing in character from Daz.
Last Active: 7 hours ago
So does the character actually HAVE a body, or is it just those parts? And which particular Daz character is it?
EvilGenius
EvilGenius
Visits: 1.1K
Kelleytoons (3/27/2019) So does the character actually HAVE a body, or is it just those parts? And which particular Daz character is it?Its a Gen 8 character. I altered some of the maps but that was it. I've done it in the past with no issues. Looks normal in Daz but once I bring it into 3DXchange it looks as if there is no body.
5 Years Ago by
EvilGenius
EvilGenius
EvilGenius
Visits: 1.1K
**crickets**
Anyone?
**crickets**
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
the first thing that come to mind ....is checking your export settings - these are the settings I use
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
I just tested this with a basic gen 8 model with the above export settings and one additional step in cc. selecting advanced and check the "embed textures" option My guess is that you didn't embed your textures from the daz export part and possibly a different fbx version than 2014.
EvilGenius
EvilGenius
Visits: 1.1K
planetstardragon (3/29/2019)
the first thing that come to mind ....is checking your export settings - these are the settings I use Thank you, I will try that.
EvilGenius (3/27/2019)
Kelleytoons (3/27/2019) So does the character actually HAVE a body, or is it just those parts? And which particular Daz character is it?Its a Gen 8 character. I altered some of the maps but that was it. I've done it in the past with no issues. Looks normal in Daz but once I bring it into 3DXchange it looks as if there is no body. Have you tried bringing in the character with the original maps? That will tell you if the issue is with the modified maps or the character itself.
EvilGenius
EvilGenius
Visits: 1.1K
the first thing that come to mind ....is checking your export settings - these are the settings I use Your suggestion did not work, unfortunately. Unsure of what to do.
EvilGenius
EvilGenius
Visits: 1.1K
Peter (RL) (3/29/2019)
Kelleytoons (3/27/2019) So does the character actually HAVE a body, or is it just those parts? And which particular Daz character is it?Its a Gen 8 character. I altered some of the maps but that was it. I've done it in the past with no issues. Looks normal in Daz but once I bring it into 3DXchange it looks as if there is no body. Have you tried bringing in the character with the original maps? That will tell you if the issue is with the modified maps or the character itself. Yes, I attempted that earlier, same result.
