max3dmaster (3/23/2019)
Problem is I could not understand anything is this software.There is obviously a learning curve. You have to invest some time to learn the software. That is why we provide an extensive list of tutorials
1. There is no zoom tool !!!
Zoom is available from the top toolbar or by pressing Z.
2. When I try to place and my objects from props, instead of letting me adjust the position and scale of my object it make animation.
That's because you are moving them when you not at Frame 1. CTA3 uses keyframe animation so moving them at any frame other than Frame 1 will place a transform key on the timeline. The result will be that the props will transition from where you placed them at Frame 1 to the new position. Just make sure you place everything at Frame 1 and you will be fine.
4. Unless we spend money and buy full software we are unable to do anything? just anything?
The trial version is for trying out the software and contains all the features of the full version. You can do everything the full version can but your output will be watermarked.
