Kimmie777
Kimmie777
Visits: 1.1K
OK, you guys... I am applying some fog for the very first time and I can genuinely use your guys' help on this. The only settings I can find for fog are color and distance. There are more fog settings than just that, right?? Right now it is much too thick for what the scene should have. I need it to be a softer / more transparent fog. How can I do this, please? ~ Kimmie P.S.: It would be really super to have a more realistic fog that has some extra patches of fog to give it depth and that realistic 'randomness'. But I will settle for at least a half-way transparent fog if there are at least the settings for that. :-)
www.TrackingJESUS.net
--> More Information On This Bible Film Production Can Be Found At: www.TrackingJESUS.net/Productions
--> Become An Early Subscriber To The 'Tracking JESUS' YouTube Channel At: https://www.youtube.com/channel/UCEMx91AySc3QuF-SS_3mGQQ
Posts: 5.7K,
Visits: 26.4K
Set the Start distance low and the End distance high. Try something like Start 200 and End 9000, then start changing the End number higher or lower to get somewhere close to what you want. Decreasing the End number will result in denser fog, increasing it gives the opposite. You can also turn "Affect to Sky" on and see if that helps any.
5 Years Ago by
Kimmie777
Kimmie777
Visits: 1.1K
Thank you. That helped some. Is there any way to make it look mistier or more like transparent clouds or something like that?
mark
Posts: 4.8K,
Visits: 16.4K
If you have the Popcorn particle effects you may be able to create a nice moving fog effect. I haven't tired to do a fog with it yet. In the past I have used the old Legacy particles (which you have with iC7) to achieve a decent fog effect. Try the "Smoke" effect and with a lot of trial and error you should be able to get what you want.
Kimmie777
Kimmie777
Visits: 1.1K
Thank you, Mark! I haven't delved into the particles yet. So I guess my next question would be for anyone who has experience in using the particles. Any advice for settings or what to try? (We don't have Popcorn FX yet, but we will be getting that as soon as we possibly can.)
mark
Posts: 4.8K,
Visits: 16.4K
Here are the rough settings for that particular Legacy Particle effect I used. It's a starting point. Now there are 4 Particle Keys... the 1st one you can see is set to 1000 Width & Height 2nd is 1500, 3rd is 2000, and 4th is 3000. As I say it's just a starting point for my scene you'll probably need to adjust for the size of the area you are trying to cover with fog.
3Aliens
3Aliens
Visits: 734
I drag the Fog down. So you have a more slighlty Fog sneaking over the Floor.
Kimmie777
Kimmie777
Visits: 1.1K
Mark: Thank you for all of that! I will try it! :-)
Kimmie777
Kimmie777
Visits: 1.1K
I have been wondering if there was a way to drop the fog down. How do I do that? When I applied my fog, it went all the way up to my trees. I only want to try some light fog low on the ground.
3Aliens
3Aliens
Visits: 734
You choose the Cursor like an normal Object.
