Sunrise765
Sunrise765
Visits: 288
I am trying to import a men's suit from Daz into CC3, but I keep getting this error message. "Failed to load character: no suitable setup profile found. Click "More" to check the compatibility list. I am using Genesis 3 as the figure. I even made sure everything was showing (feet, arms, chest, etc.). I don't know how to fix this problem. Can somebody help me to solve this problem, please? Thanks
Last Active: 10 minutes ago
Posts: 9.1K,
If you tell me the exact Daz clothing item I'll be glad to tell you how to do it.
mtakerkart
mtakerkart
Last Active: 14 hours ago
Posts: 3.1K,
Visits: 28.2K
Do you know Kelly if it is possible to recover hidden polygons in Daz ? Because the probleme with your method is that the clothed finger doesn't work in cc3 , the transformer is not apply on the fingers...
armetral_18
armetral_18
Visits: 392
I can't add anything to custom panels from a daz transformed characters in the new version of cc3. The add plus sign never turns on to add.
Posts: 9.1K,
mtakerkart (3/13/2019)
Do you know Kelly if it is possible to recover hidden polygons in Daz ? Because the probleme with your method is that the clothed finger doesn't work in cc3 , the transformer is not apply on the fingers... I've never had any luck adding hidden polygons, but I've always been able to work around it. If you tell me exactly what Daz thing you are trying I'll see if I can make it work (it looks like it's the android parts which I both have and have brought into CC3, but there are a LOT of different ones. Tell me the exact name and what you are trying and I'll see what the workflow should be).
Posts: 9.1K,
armetral_18 (3/14/2019) I can't add anything to custom panels from a daz transformed characters in the new version of cc3. The add plus sign never turns on to add.I would try uninstalling both versions (you have two versions of CC3 -- the "regular" and the pipeline addition) and then reinstalling through the hub.
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
Thanks Kelly. I bought this 2 packages : https://www.daz3d.com/arctek-cybernetic-arms-for-genesis-8-femalehttps://www.daz3d.com/arctek-cybernetic-legs-for-genesis-8-femaleWhen I tried to rework and apply the fingers weightmap , polygons move away from the bones....
Posts: 9.1K,
All right, I'm going to eat some breakfast but let me see what I can do after that.
Posts: 9.1K,
It's pretty simple. After you get the arms in, just apply Transfer Weights using the gloves preset. All will then be well.
Posts: 9.1K,
And here's the whole thing:
