iClone 7 to Unity with Motions
Posted By Dan Miller 5 Years Ago
Dan Miller
Dan Miller
Posts: 365, Visits: 1.8K
I watched an older video exporting to Unity with motions but got stuck. My understanding now is we can export directly from iClone 7 but if we want to import then we use 3DXchange. Does that sound correct? I recorded facial mocap and various motions that I would like to export to Unity with the character, so I did export as FBX. The character and materials exported but no motions. Am I doing it wrong? Thanks.
akuei2
akuei2
Posts: 110, Visits: 2.4K
Here my workflow:
3rd party motion
eg. DAZ motion => 3dxchange => IC7 => Unity (60FPS, Humanoid).
Reallusion Motion
IC7 => Unity(60FPS, Humanoid)
Unity Motion
Prepare character on CC3 or IC7, make sure motion work in IC7. After that, export to Unity with humanoid rig.
Then, assign animation in animator or timeline.
Important: You must test everything well in IC7, before you export to Unity.
Dan Miller
Dan Miller
I appreciate you sharing your workflow. I'm attempting to export from IC7 to Unity. I selected Unity3D, 60fps, and All. I do not see a selection for humanoid rig. I will try the export anyway to see if it works but where are you selecting humanoid before export from iClone 7? Thanks.
Dan Miller
Dan Miller
Hmm, I'm having some trouble. So I import into Unity with T-pose but unable to get the avatar working in Humanoid. When I look at the avatar it says not in T-pose and few bones are in red. When I click on the bones, it is assigned correctly so no changes need to be made.
When I drag the animation to the timeline I get something completely unexpected. I'm not sure how to explain it but there doesn't appear to be any content. Do I have to have something highlighted in iClone 7 before export? It's like the animation is there but with no content.
Dan Miller
Dan Miller
Duration of the animation is 0.01 to 1. So something to drag to the timeline but my motions did not come over from iClone.
Last Active: 1 minute ago
Posts: 8.1K, Visits: 60.5K
I think they mean to select "Unity 3D" from the drop-down menu at the top of the panel.
You do need to select the character in iClone scene that you want to export.
Dan Miller
Dan Miller
Ok, this is what I select for export. Do I need to highlight anything in the timeline in iClone 7 before export? I am just highlighting, in this case, Christian_CC. Maybe I need to highlight Christian, Motion, and Viseme in order to get it to export everything.
https://forum.reallusion.com/uploads/images/368ff97c-7944-486c-9728-1966.jpg
You also need to set a range frame-range. The way you have it set now, you are only exporting a single frame.
Select a range that encompasses the motion you are trying to export.
5 Years Ago by Rampa
Dan Miller
Dan Miller
I will give that a try. When I did that the first time I selected All so I would get everything. But then in Unity it said it needed a T-pose. I will try again, thanks.
