ZBrush 2019 Update and Now GOZ Doesn't Work
Posted By DavidinLA 5 Years Ago
DavidinLA
DavidinLA
Veteran Member (793 reputation)Veteran Member (793 reputation)Veteran Member (793 reputation)Veteran Member (793 reputation)Veteran Member (793 reputation)Veteran Member (793 reputation)Veteran Member (793 reputation)Veteran Member (793 reputation)Veteran Member (793 reputation)
Posts: 51, Visits: 471
I updated Zbrush to 2019 today. When I went to use GOZ with CC3 I received a message "Zbrush application was not found. Verify...."
You can see in the attached screen shot that Zbrush is open in the tray when I get the message. I tried to put a shortcut in the Zbrush2018 folder and that didn't work.
How can I correct the issue?  Is it a path thing? Do I have to use the old Zbrush 2018 with CC3?
Any help is appreciated. Thank you.
https://forum.reallusion.com/uploads/images/4d8304fd-e138-4c4c-ba2d-f5c6.png
DavidinLA
DavidinLA
Just a note - I reinstalled Zbrush 2018 and that does open up with GOZ from CC3. I would like to use the new and slightly improved Zbrush 2019 though if possible. So if any suggestions...
vidi
vidi
Distinguished Member (31.6K reputation)Distinguished Member (31.6K reputation)Distinguished Member (31.6K reputation)Distinguished Member (31.6K reputation)Distinguished Member (31.6K reputation)Distinguished Member (31.6K reputation)Distinguished Member (31.6K reputation)Distinguished Member (31.6K reputation)Distinguished Member (31.6K reputation)
Posts: 10.8K, Visits: 40.2K
Is it a path thing?
yes
For me it works in Zbrush 2019 wihout any changes  , but in your case remap the aplications that are GOZ-able  in the preference menue in Zbrush
liebe Grüße vidi
DavidinLA
DavidinLA
Thank you for your help. It didn't occur to me to attack the issue from the Zbrush side but that makes sense in retrospect. Would you say it's OK to go ahead and uninstall ZB2018?
