ivica.valentic
ivica.valentic
Visits: 359
Hi, avatarThere are two sizes and I need less. When I lower it (without pants) and switch to Iclone, a smaller one then looks at the cross and eyes dance to him. I tried to fix it in 3dxchange but I can not fix it.If I import it from the DAZ reduced then the morph breaks down into cc3. Please help. Thank you
Last Active: 11 hours ago
The small one works fine for me imported with Transformer (and then sent to iClone). In iClone I can move the eyes around without any problems. Can you be more specific about your workflow? In Daz you first bring in the full sized Pixie and then you apply the 14mm Duf file to it, which reduces it. Then you should export it, and then use the Transformer button in CC3 and choose either Basic or Advanced (doesn't matter which -- Advanced will bring in skin textures but that's the only difference). In CC3 then just Export to iClone and you should be okay. Let me know if this doesn't work and I'll make a short video showing how I did it in the morning.
ivica.valentic
ivica.valentic
Visits: 359
I do not know where the mistake is. 1) transformer 2) big and samall 3) When I add genesis 3 gesture increases itself. 4) I lower it again 5)export> 3dx 6) control 7) Look at the cross. Manual adjustment. 8)mesh crazy 9)Uninstalled pipeline cc3 and try again with a transformer big and small
Last Active: 3 hours ago
Visits: 60.6K
You should transform the regular-size version. There is a very effective scale by percentage in iClone for CC characters. It works with no distortion. Once scaled-down, you can save the character that way in iClone, or sent back to CC3.
But it also works with the small version, Rampa -- tested it myself. I'll put together a video after I eat showing this procedure.
ivica.valentic
ivica.valentic
Visits: 359
I exported a big one. This message comes from CC3. In 3dx all keys are Ok. My eyes were looking at the cross so I fixed them manually. Export> IC7. There, in the animation, the eyes still dance.
Okay, here's the procedure. The problem the OP ran into, I think, is the classic "clothing hides part of mesh" which causes Transformer to burp. Easily solved.
ivica.valentic
ivica.valentic
Visits: 359
There must be a language barrier here. 1) The small pixie works fine for me in iClone, as I demonstrated. 2) I really have ZERO idea what you are saying here 3) Same here -- eyes work fine for me in iClone, as I showed in the video. You'll either need to elaborate or perhaps you can make a video which shows things as I did.
ivica.valentic
ivica.valentic
Visits: 359
1) I figured why my eyes are dancing on video 1 and 2 2) reduced export yields bad form-video 2
https://www.youtube.com/watch?v=naStYz8Q8fU[/YouTube]
