emanicus
emanicus
Visits: 66
If I import a character from DAZ3D to CC3 using "Transformer" option I get feet separated from the shoes. Tried with G8, G3 this issue is consistent no matter what... how do you fix it please? Thank you, e.
Last Active: 6 hours ago
Posts: 9.1K,
Visits: 21.7K
Select the shoes, go to Attribute Tab and Edit Mesh, and select each shoe and move them over to fit.
Posts: 22.6K,
Visits: 35.6K
You shouldn't get this if the shoes are correctly conformed to the Daz Genesis character. I don't have any problems getting shoes to come into CC3 correctly conformed so it is likely a Daz Studio setup issue or an issue with the shoes you are using (unlikely). Do check the shoes are correctly conformed to the character and you have your export settings correct such as having "Merge Clothing into Figure Skeleton" checked.
emanicus
emanicus
Visits: 66
YES! it did work moving them manually but I agree with Peter(RL) I think there is something wrong when they are exported from DAZ3D, will check the parameters he suggested. But thank you at least for now I can fix them and move forward... before I was really stuck and could not use any on the characters!!!
emanicus
emanicus
Visits: 66
Thanks Peter!!! IT WORKED!!! I did not have "Merge Clothing into Figure Skeleton" checked... what else needs to be checked...!?!?! I posted a screen print of the export window. Is everything else OK?
Posts: 22.6K,
Visits: 35.6K
Hi... Please see the tutorial below which shows the export settings you need when using Transformer. https://youtu.be/OT1IzuPx8cg?list=PLNV5zSFadPdmyOVE2c3RrOqLZS-KfiEZK&t=68
emanicus
emanicus
Visits: 66
Thank you Peter will do!
