Issue importing from Mixamo
Posted By omegaav 5 Years Ago
omegaav
omegaav
Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)Veteran Member (882 reputation)
Posts: 61, Visits: 617
I have made a model in Adobe Fuse and then rigged in mixamo but when I open it in 3d Xchange the character has its hands above its head and is all corrupted. look at imagehttps://forum.reallusion.com/uploads/images/f2575fd4-6810-46f3-a804-8ad5.jpg
I am new to all this so any advice/tips will be appreciated
Posts: 9.1K, Visits: 21.8K
How did you map the bones in 3DX?
omegaav
omegaav
Hi,
Once I have brought it in I select Character/Convert to Non-Standard, there are no presets available they are all greyed out
Then I select apply to iClone
As I have said I am very new to all this, and in addition into my 60's so age may not be on my side!!!
You have to map the bones yourself.  Let me see if I can find a video tutorial on this process:
Okay, found one.  Look at the 1:50 mark here and it should explain what you need to do.  Let us know if you have any difficulties with this process:
omegaav
omegaav
I followed the video, but  I still cannot select any of the bones, the dot in the top left corner is green compared to the video where it is red.
I have tried with and without animation but still no luck, I will re install the software just in case there is a problem there but any further help would be greatly appreciated
You might have to post a link to your model -- I don't know what else to tell you (but if the bones are green try turning off the t-pose and see if that allows you to then select them properly).
omegaav
omegaav
I have turned off T.Pose and the legs disappear.
There are a number of animations which I can select but all of them look like the initial image i posted but they are moving, they resemble an inflatable doll.
How will i be able to share the link to my model as you have suggested, I am quite happy to allow someone to take control of my computer to see if its something I have done.
I have noticed that if I use the y.bot character rather than a character i have made in Fuse it works ok
Just upload your model somewhere -- there are a lot of free cloud services (I like Mega).  Then provide a link to it.
omegaav
omegaav
Thanks for your help here is the link:
https://mega.nz/#!itl1FQ6I
I have just tested it in cinema 4D and it works fine
Hopefully you will be able to find out the problem
You created the link with an encryption key, which I do not have.
You can create the link without the key so that anyone can download, or you can provide the key.
