Rottadamic
Rottadamic
Last Active: 3 days ago
Visits: 981
what the bliep? I can not save anything in the custom bar anymore, not even stuff I made and stored there, I can not resave wy and how to fix?
Posts: 9.1K,
Is it possible you accidentally converted that to an accessory or some other type? Check it in the attribute tab. It should have "Convert to accessory" as an option (but also try transferring cloth weights to it).
Rottadamic
Rottadamic
Visits: 981
no, that is not it. I can not save anything anymore. it is like that function is disabeld
It may be there is a registry issue where the information about your installed content folders has changed in some way. If you are familiar with the editing of the registry, please check the following:
1) Type "Regedit" in the Search box on your Taskbar and select the "Registry Editor". 2) Navigate to the address below: HKEY_LOCAL_MACHINE\SOFTWARE\Reallusion\Shared Data
3) Check the "Custom Data" folder location is correct. For example, the default install location should be: "C:\Users\Public\Documents\Reallusion\Shared Custom"
4. Now check to see if there is a space " ", or an additional "s" in the folder name, and correct if it is wrong. 5. Restart Character Creator 3 and check if the issue is resolved.
Rottadamic
Rottadamic
Visits: 981
I don't know/ find point 1 and 2 but for the rest, I check, and compared the name whit backups and that has not changed. Now i think I need to mention this happened after i removed iclone 6 and cc2 from my pc Do I need to reinstall cc3?
Rather than spend a lot of time troubleshooting, reinstalling will be worth trying and may resolve the issue straight away. You won't need to reinstall all your content so it won't take too long.
Rottadamic
Rottadamic
Visits: 981
i completly reinstalled and it works now
That's great to hear. Thanks for letting us know.
