Daemonspike
Daemonspike
Visits: 942
Hey thebiz, I just found out now to do what I think you asked for (This is something Ive been struggling with recently. In Sketchup you could group parts of the model together and they would import into 3DX as subprops. I have not found this ability in Blender and so far am forced to export all the pieces separately. Am I missing something?)If you create multiple objects in blender and export, then it seems like you have to make sub-props in 3DXchange, it worked for me. Click on object to the left and to the right click the button Make Sub-Prop /Mike
5 Years Ago by
Daemonspike
4413Media
4413Media
Visits: 7.4K
Daemonspike (2/15/2019) Ah ok thanks. Benjamin, as I am very new at Blender could you you explain a bit further how to do that in this case with the simple cube? Btw I did not UV map in 3DXchange during this test. I just created a cube and checked the generate UV while creating the cube in Blender.
/MikeThink of it like unfolding and flattening a box. Since you set a default uv map, it unfolded it fit in a single map, which resulted in that picture above. This video will explain the process better than I can.
iClone Certified Director and makes miserable Westerns.
Daemonspike
Daemonspike
Visits: 942
Thanks Benjamin, yeah like sheet metal folding. Also explain "and makes miserable Westerns." a bit further : - )
/Mike
5 Years Ago by
Daemonspike
Daemonspike (2/15/2019) Thanks Benjamin, yeah like sheet metal folding.
Another fantastic way to think of textures, and UV Map (unwrapping), is to look at a "sewing pattern" that a seamstress or tailor uses to make clothing. (See these pictures.)
You take a flat, 2D piece of cloth, cut shapes, and then it gets "wrapped" onto your 3D body. Taking an X-Y location on the pattern and connecting it to an X-Y-Z location on your body is the "mapping" process, and on the flat pattern. In an attempt to avoid using the same letters in two places, rather than use the letters X and Y on the flat 2D texture (the cloth), we use the letters U and V. Thus the flat square cloth is a UV map.
This description is quite literal in terms of what happens. It explains why your "brick texture" can end up in all sorts of weird orientations on your object, just like stripes on your cloth can result in stripes that go up and down your sleeve, or around in rings, depending on how you laid the "sleeve shape" on the cloth when you cut it out.
It also explains why you can have "blurry textures." If you made your sleeve shape really small on the cloth, and then had to stretch it 10x larger so it would fix on your arm, the texture on that part of the cloth would be very pixelated looking, while other parts of the shirt might look fine.
Welcome to the world of quality unwrapping and texel density.
5 Years Ago by
thebiz.movies
thebiz.movies
Last Active: 3 hours ago
Posts: 2.0K,
Visits: 41.1K
Hey thebiz, I just found out now to do what I think you asked for (This is something Ive been struggling with recently. In Sketchup you could group parts of the model together and they would import into 3DX as subprops. I have not found this ability in Blender and so far am forced to export all the pieces separately. Am I missing something?)If you create multiple objects in blender and export, then it seems like you have to make sub-props in 3DXchange, it worked for me. Click on object to the left and to the right click the button Make Sub-Prop /Mike Hey Daemonspike, I create two seperate objects in Blender in the object mode. I export into fbx mode. They show up in 3DX as one object. Perhaps Im missing something..
5 Years Ago by
thebiz.movies
Daemonspike
Daemonspike
Visits: 942
thebiz from your screenshot I think I know what might be wrong. You must make sub props of all objects, the root one should be a container, not part of the objects below. I had the same problem earlier today when I tested. - RootNode(filename) +cube +Sphere +Cube2 /Mike
5 Years Ago by
Daemonspike
thebiz.movies
thebiz.movies
Posts: 2.0K,
Visits: 41.1K
Theres only one object in my example. I cannot select a separate cube in 3DX to create a subprop because the two are exported as one. Yours has two. Perhaps its a setting in the export from Blender that I missed.
Daemonspike
Daemonspike
Visits: 942
"Welcome to the world of quality unwrapping and texel density. "
Hehe justaviking, that post of yours is worth gold, much good information packed into one post.
5 Years Ago by
Daemonspike
Daemonspike
Daemonspike
Visits: 942
thebiz, are you sure there is two separate obejcts in Blender? Is your Blender scene tree saying like World +Cube +Cone Two separate obejcts? If you save to fbx when imported to 3DXchange they will end up under root node but you still have to click every objects name and make them Sub-Props.
thebiz.movies
thebiz.movies
Posts: 2.0K,
Visits: 41.1K
Yes, two separate objects in blender. One in 3DX. Hence my issue. I played with the objects as obj objects and objects as obj groups options in blender with no affect. Its got to be something simple that will make me feel dumb. But what?
