charly Rama
charly Rama
Posts: 1.9K,
Visits: 16.9K
For the moment, I love Iray. It's okay for me for time rendering, I render 30 s of animation during just one night so no time wasted. The big problem is : I can't use particles, the DOF doesn't work well as the native render, and fog is missing. For the water, I use soft cloth with video texture, it's really ok but we also need REAL FLOW as in other 3D softwares using it. That's a big limitations for Iray but one more time, I LOVE Iray.
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Charly! YES - I too *LOVE* the 'look' of Iray... But the *limitations* - yes, there are limitations - the most basic being *time*. But - if you've got the time, AND you can live with the other 'constraints' - it's a terrific end result and a *great look* for sure ....
5 Years Ago by
sonic7
charly Rama
charly Rama
Posts: 1.9K,
Visits: 16.9K
Yes, Steeve, I've pushed so far and I renderd with 20 iterations, denoising 19, It was fast I'll show here the result, not too bad. It's really nice. I'm looking for a way to "cheat" as with the water for the fog and particles using transparent videos, we will see...
charly Rama
charly Rama
Posts: 1.9K,
Visits: 16.9K
When will this possible ? It's Iray, and it's water
Last Active: 10 hours ago
Posts: 15.7K,
Visits: 30.5K
The DOF works for me, but I change certain settings in iClone, which are not realistic. I set Perfect Focus Range to 0 and then only use Focus Distance and Transition Region. Occasionally, I also adjust the Blur Strength. If you want to get fancy, you can render a Depth map out of Iray and do the DOF in post.
charly Rama
charly Rama
Posts: 1.9K,
Visits: 16.9K
Thank you Animagic, I'll give a try of that.
When I have to use particles, I 'm forced to use nativ render .
Posts: 15.7K,
Visits: 30.5K
I've been wondering if it would be possible to somehow combine the Iray render with the native render, which would provide the particles.
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
@Job " ..... If you want to get fancy, you can render a Depth map out of Iray and do the DOF on post ..... " Yes, I've heard that said before, but now you've got me thinking ... This method of rendering out an Iray 'depth map' I'd assumed was for creating DOF looks on 'Iray' renders (in post). But I wonder how it would work (the same approach), combining an Iray depth map - but with standard iClone renders? - could be interesting - I might do some testing ...
Skuzzlebutt
Skuzzlebutt
Visits: 8.6K
if you use After effects or hitfilms a depth map is a easy way to composite in them pesky particles you also have the same geometry and cameras so you can turn obstructions into mattes and everything composites with little fuss
Last Active: 8 hours ago
Visits: 60.6K
It's actually really easy to create a iClone render depth-map as welI. You basically just kill the lights in your scene and turn on the fog set to white. Adjust the fog range so the far away is as white as you like, and the immediate foreground is black (not effected by white fog).
