SetTransitionStrength()
Posted By RobertoColombo 5 Years Ago
RobertoColombo
RobertoColombo
Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)
Posts: 1.6K, Visits: 3.0K
HI all,
after scratching my head for a while because of the bizzarre behavior, I finallz found that the value we set with SetTransitionStrength() shall be related to the time where we set a key frame.
I found that if the value that we set is higher than the time (in msec) where we want to put a key, the key characteristic is spoiled.
So far, I tried with the Diffuse Color, not sure for other key settings...
Just try the following code, which creates a cube and set it to a green color after 100 msec with a linear transition.
Try first transition strength <= 100, and after put it > 100 (even 101...) and see what's happening... WinkWinkWink
Cheers
  Roberto
from winreg import *
import os, RLPy
# Plug-in entry point
def run_script():
    #-- Get iClone 7 default template path --#
    Registry = ConnectRegistry(None, HKEY_LOCAL_MACHINE)
    RawKey = OpenKey(Registry, r"SOFTWARE\Reallusion\iClone\7.0")
    ic_template_path = os.path.abspath(QueryValueEx(RawKey, "Template Data" )[0])
    #-- Load Box_001.iProp --#
    RLPy.RFileIO.LoadFile(ic_template_path + "//iClone Template//Props//3D Blocks//Box_001.iProp")
    #-- Get Prop --#
    prop_obj = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, "Box_001")
    if prop_obj is not None:
        mesh_names = prop_obj.GetMeshNames()
        material_component = prop_obj.GetMaterialComponent()
        material_names = material_component.GetMaterialNames(mesh_names[0])
        diffuse_color = RLPy.RRgb().From(0, 100, 0)
        R_Key = RLPy.RKey()
        R_Key.SetTime(RLPy.RTime(100))
        R_Key.SetTransitionType(RLPy.ETransitionType_Linear)
        R_Key.SetTransitionStrength(50)
        material_component.AddDiffuseKey(R_Key, mesh_names[0], material_names[0], diffuse_color)
    else:
        print("Can't create the prop!!!")
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
RobertoColombo
RobertoColombo
mmmh... the situation seems even worst.
Launchin this same script multiple times, each time with different values for the keyframe time and transition strength, I often get random results for the assigned color: sometimes it is assigned correctly, sometimes th eprop glows like crazy, other times it is black... weird... Blink
Not sure if others experience the same...
My PC:
5 Years Ago by RobertoColombo
Last Active: 11 hours ago
Posts: 9.2K, Visits: 21.8K
Either there's a language barrier or a brain barrier here, Roberto, but I'm not quite understanding your issue.  However, in any case, have you tried using a step transition where you want to pin the color properly?  Using any other kind of transition (even doing it by hand) in the timeline DOES produce weird effects in color changes, but that would be expected.
RobertoColombo
RobertoColombo
H Mike,
first of all, it is not true that the transition curves on key frames generate strange results.
They work pretty fine indeed!
Just put a simple box in a scene, assign a diffuse color at a certain frame, e.g. 300, then play with the transition keys and you will that the color transition follows the transition curve as expected.
Said, this, I come back to the problem.
I want to do the simplest thing: setting the diffuse color of a prop.
Let's even make it simpler: I want to assign the color at time 0, i.e. the 1st frame.
So, let's go steps by steps...
Here there is a nice example: http://manual.reallusion.com/iclone/script/python/md_docs__way_to_control_prop.html
...but unfortunately that code is bugged!!
Just copy-paste it, run it and you should got the error: <class 'TypeError'>, File: C:\Program Files\Reallusion\iClone 7\Bin64\RLPy.py, Line: 8340
So, here we have another shoot: http://manual.reallusion.com/iClone/script/python/class_r_l_py_1_1_r_i_material_component.html#a05e80611f15b115595bc2dfd2ea12579
I can successfully load a texture, so I thought that it would be a piece of cake to use the same  way to assign the diffuse color.
The code I pasted above is just a semplification of the the example in that page... but t does not work.
I get strange results...
Perhaps there is another way to set a color, but unfortunately this is what RL documented: one bugged example and another that ends into strange results Sad
Any hints ?
  Roberto
PS: of course if you had learned Italian language instead of keep on playing tennis, right now there would be no language bareer BigGrinTongue
My PC:
videodv
videodv
Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)
Posts: 342, Visits: 12.0K
RobertoColombo (2/7/2019)
H Mike,
Any hints ?
  Roberto
Hi Roberto
I have had a tinker with this and come up with the following script just run the script first press the get colour button and select a colour from the colordialog second press the place prop button the just scroll the timeline a little and you should see the colour you selected.
What I have found is sometimes the colour selected from the colordialog will not show correctly but I think this is to do with setting the red green and blue variables to int or simular.
anyway hope this helps.
here is the code
import PySide2, RLPy
import colorsys
from PySide2 import *
from PySide2 import QtWidgets
from PySide2.QtCore import Qt
from PySide2 import QtGui
from PySide2.shiboken2 import wrapInstance
import os, math
#-- Make a global variable contain dialog --#
sample_dialog = None
def openColorDialog():
    Opens the color dialog
    global color
    color = QtWidgets.QColorDialog.getColor()
def get_prop():
    #-- Get Prop --#
    prop = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, "Box_001")
    #-- Get Material from Prop --#
    material_component = prop.GetMaterialComponent()
    mesh_list = prop.GetMeshNames()
    mesh_name = mesh_list[0]
    material_list = material_component.GetMaterialNames(mesh_name)
    material_name = material_list[0]
    alpha = color.alpha()
    red = color.red()
    green = color.green()
    blue = color.blue()
    # 208 48 197
    diffuse_color = RLPy.RRgb().From(255, 127, 0)
    R_Key = RLPy.RKey()
    R_Key.SetTransitionType(RLPy.ETransitionType_Step)
    R_Key.SetTransitionStrength(100)
    #-- Add diffuse key --#
    material_component.AddDiffuseKey(R_Key, mesh_name, material_name, RLPy.RRgb().From(red, green, blue))
def run_script():
    global sample_dialog
    sample_dialog = RLPy.RUi.CreateRDialog()
    sample_dialog.SetWindowTitle("Sample Dialog")
    #-- Create Pyside layout for RDialog --#
    pyside_dialog = wrapInstance(int(sample_dialog.GetWindow()), QtWidgets.QDialog)
    #pyside_dialog.setFixedWidth(300)
    sample_layout = pyside_dialog.layout()
    #-- Add PushButton --#
    colourbutton = QtWidgets.QPushButton("Get Colour")
    sample_layout.addWidget(colourbutton)
    pushbutton = QtWidgets.QPushButton("Place Prop")
    sample_layout.addWidget(pushbutton)
    colourbutton.clicked.connect(openColorDialog)
    pushbutton.clicked.connect(get_prop)
    sample_dialog.Show()
Chris.
RobertoColombo
RobertoColombo
Hi Chris,
I would like to nail down a bit the problem.
This is the relevant part of your code:
    red = color.red()
    blue = color.blue()
    # 208 48 197
    R_Key = RLPy.RKey()
Note that in yoiur code you set the diffuse_color but actually you never use it.
In fact. you add a key at a certain time, with strength = 100, and the RGB set by the "color" object, which gets updated by the QColor widget.
Now, if you look at my code, I simply removed all the GUI stuff and just worked directly on the prop, setting a key with a fixed color and I am basically doing the same:
1. create a RKey object,
2. set its color,
3. assign to the prop.
        R_Key = RLPy.RKey()
        # I tried also to set the transition type to STEP but the inconsistency in behavior is still there...
Doing this i see random behavior, not consistent: sometimes the prop is set to clack and if I look at the diffuse box in the material window I can effectively see it as black together with the keyframe (hide/unhide shows the keyframes) !!!
I tried to change the transitoin to STEP but i do not see any difference in behavior.
What is your experience if you try to copy-paste my code and execute multiple time, deleting the added prop before every launch, amnd also changing the Key time and strength ?
I tested the border cases, e.g. time = 0, strength != 0, or time = X ( > 0 ) and strength higher or lower than X, etc.
Also, I tried to run the script N times, with different values...
Behavior is not consistent!
I will do some more experiment later, creating a loop, where for each iteration I create the same prop again and displace on the X axis by a fixed amount, so that all the props are visible, and logging the assigned RGB color values, so that I can compare the values passed to the key and what is the final color in the scene.
Also, I would lke somebody from RL to explain:
1. whether the transition type and strength is mandatory when we set a key (it should not be! The proper behavior should be that it default to a fixed setting, and this should be documented somewhere)
2. what is really the strength: how the plugged number behaves and whether is there any relationship with the keyframe absolute time and relative time from the previous keyframe
3. why the codes on their website are bugged and misbehaving: did they test it ? Publishing bugged or wrong code simply waste our time...
  Roberto
My PC:
videodv
videodv
Hi Roberto
The code I put up I started about a week ago and been trying to get a satisfactory result ever since, but I have found the same as you, the results have been inconsistant at best no matter what values I try the same as you as well.
I tried you code as well and got the same results too i.e inconsistant.
I agree the documentation is lacking to say the least at best head scratching at worst not working at all, RL really need to take some time and work on this aspect of the API so we all can get a handle on whats what.
I will be looking at this again this evening when I have more time although I feel unless we get more help from RL not sure how far we can go to get a consistant outcome, it has been a frustrating week for me trying to just change the colour of a prop to one of my choosing.
Chris.
RobertoColombo
RobertoColombo
Hi Chris,
thanks for the answer.
So, it seems I am not the only one to find weird behavior with the diffuse color settings.
Till RL clarifies whether there is a bug or are we doing something wrong, I will stop here for this part of the API and move to other ones.
Cheers
  Roberto
My PC:
videodv
videodv
RobertoColombo (2/8/2019)
Hi Chris,
Cheers
  Roberto
Hi Roberto
After a couple of hours on this with the same issues, I think like youself I will give this a rest for now as I also have other things going on so will wait for RL to get back (hopefully soon) with an answer with this issue.
Cheers
Chris
AllenLee (RL)
AllenLee (RL)
Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)
Posts: 54, Visits: 526
HI all,
Cheers
  Roberto
import os, RLPy
def run_script():
    #-- Get Prop --#
        R_Key = RLPy.RKey()
    else:
Hi Roberto,
We found a bug in the RLPy.RRgb.From( x, y, z ).
You can try this:
diffuse_color = RLPy.RRgb(0, 100/255, 0)
Allen
