Python: AddDiffuseKey not showing on timeline
Posted By videodv 2 Weeks Ago
videodv
videodv
Posted 2 Weeks Ago
Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)
Last Active: 16 minutes ago
Posts: 156, Visits: 3.9K
Hi All
After the update to 7.41 when I add a series of Material Diffuse Keys to the timeline and playing the sequence the key do not show up, anyone else found this or is it just my system?
I have put this in the feedback tracker but got no responce yet to this issue.
Chris.
The-any-Key
The-any-Key
Posted 2 Weeks Ago
Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)
Posts: 110, Visits: 618
Try hide/unhide the object.
videodv
videodv
Posted 2 Weeks Ago
The-any-Key (2/3/2019)
Thanks The-any-Key
That did the trick.
Chris.
dogged2003
dogged2003
Posted 2 Weeks Ago
Last Active: 5 hours ago
Posts: 380, Visits: 3.8K
Smile First - play
Second - hide/unhide
What will next? Wink
My YouTube channel.
videodv
videodv
Posted 2 Weeks Ago
dogged2003 (2/4/2019)
Smile First - play
I have my hide unhide script so easy to do now I know Smile
Chris.
RobertoColombo
RobertoColombo
Posted 2 Weeks Ago
Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)
Posts: 1.6K, Visits: 3.0K
Hi,
question: what is the API to set the RGB values for a RLPy.RRgb object ?
Not sure if it is a "typo" but the doc has a kind of duplicated API, both of them saying that they are used to get the color component, e.g. RLPy.RRgb.Red() and RLPy.RRgb.R().
So I tried the
RLPy.RRgb.R() passing an integer as a parameter but I got an error.
Any idea/hint ?
Thanks
Cheers
  Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO /
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the VB with an HDMI splitter) / DirectX: 12
2 Weeks Ago by RobertoColombo
The-any-Key
The-any-Key
Posted 2 Weeks Ago
Try:
# Color object
col_obj=RLPy.RRgb()
# Get color object from object
# Get colors
r=col_obj.R()
g=col_obj.G()
b=col_obj.B()
# Custom red
r=255
# Set
col_obj.From(r,g,b)
2 Weeks Ago by The-any-Key
RobertoColombo
RobertoColombo
Posted 2 Weeks Ago
Thanks!
I missed this one: col_obj.From(r,g,b)
That's what i need Smile
  Roberto
My PC:
RobertoColombo
RobertoColombo
Posted 2 Weeks Ago
Hi Jeff,
I tried what you suggested but i still get a run-time error.
Basically, the error pops up as soon as I build a simple RGB object, e.g., something like:
   color = RLPy.RRgb.From(150, 40, 200)
Note that I can successfully create a prop and change its color to RED, GREEN, or BLUE using
   color = RLPy.RRgb.RED, or
   color = RLPy.RRgb.GREEN, or
   color = RLPy.RRgb.BLUE
but when I substitute this instruction in the same code with the one above, I get an error.
Puzzling... Blink
  Roberto
My PC:
jlittle
jlittle
Posted 2 Weeks Ago
Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)
Posts: 1.5K, Visits: 11.5K
Try putting parens after RRgb:
 color = RLPy.RRgb().From(150, 40, 200)
Jeff
