videodv
videodv
Visits: 12.0K
Hi All
After the update to 7.41 when I add a series of Material Diffuse Keys to the timeline and playing the sequence the key do not show up, anyone else found this or is it just my system? I have put this in the feedback tracker but got no responce yet to this issue.
Chris.
The-any-Key
The-any-Key
Visits: 1.9K
Try hide/unhide the object.
videodv
videodv
Visits: 12.0K
The-any-Key (2/3/2019) Try hide/unhide the object.Thanks The-any-Key That did the trick. Chris.
dogged2003
dogged2003
Visits: 4.5K
The-any-Key (2/3/2019) Try hide/unhide the object. First - play Second - hide/unhide What will next?
My YouTube channel.
videodv
videodv
Visits: 12.0K
dogged2003 (2/4/2019)
The-any-Key (2/3/2019) Try hide/unhide the object. First - play Second - hide/unhide What will next? I have my hide unhide script so easy to do now I know
Chris.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hi, question: what is the API to set the RGB values for a RLPy.RRgb object ? Not sure if it is a "typo" but the doc has a kind of duplicated API, both of them saying that they are used to get the color component, e.g. RLPy.RRgb.Red() and RLPy.RRgb.R(). So I tried the RLPy.RRgb.R() passing an integer as a parameter but I got an error. Any idea/hint ?
Thanks Cheers
Roberto
5 Years Ago by
RobertoColombo
The-any-Key
The-any-Key
Visits: 1.9K
Try: # Color object col_obj=RLPy.RRgb() # Get color object from object ... # Get colors r=col_obj.R() g=col_obj.G() b=col_obj.B() # Custom red r=255 # Set col_obj.From(r,g,b)
5 Years Ago by
The-any-Key
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Thanks! I missed this one: col_obj.From(r,g,b) That's what i need Roberto
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hi Jeff, I tried what you suggested but i still get a run-time error. Basically, the error pops up as soon as I build a simple RGB object, e.g., something like: color = RLPy.RRgb.From(150, 40, 200) Note that I can successfully create a prop and change its color to RED, GREEN, or BLUE using color = RLPy.RRgb.RED, or color = RLPy.RRgb.GREEN, or color = RLPy.RRgb.BLUEbut when I substitute this instruction in the same code with the one above, I get an error. Puzzling...
Roberto
jlittle
jlittle
Last Active: 24 minutes ago
Posts: 1.9K,
Visits: 17.1K
Try putting parens after RRgb: color = RLPy.RRgb ().From(150, 40, 200) Jeff
