Rampa (2/3/2019)
Since the folders and structures are the same in every template or custom folder, you can just drag your "wrong" template folder onto your "right" one, and Windows will merge the wrong into the right.
If you want to choose a new location altogether, you only need to install 7.41, choose your location, and then merge your other folders into the new one you created.Thanks again for the help Rampa
I did the Windows wrong to the right folder thing.
I can't select D:\ to install the Reallusion folder that is used for iC6.
Right now my custom folder is located at D:\Reallusion7\ but I can't use that as it is an impossible folder location.
So I'll have no choice but to end up with D:\%something%\Reallusion\ to place my custom folder.
I'll end up having to do the Windows wrong to the right folder thing to the D:\Reallusion7\custom folder to the new folder location.
What I can't understand how was I ever able to select the impossible folder location when I first installed iC7 in the first place?
Instead of D:\Reallusion7\Reallusion\
It went to D:\Reallusion7\
5 Years Ago by
Dragonskunk
