Thanks Dogged, Animagic
OK, 4 people besides myself seem interested in this application for doing this so I will take that as meaning it will be beneficial for posting my improvements to this code I made
I will be working on it some more soon I think. I was doing the code for the 69 Dinosaurs I have manually. It took me nearly 8 hours to do 3 of them so I ended up spending 2 hours to write this HTA code.
Turned out to be beneficial for me because I did the other 63 of them yesterday in 3 hours....so it was worth it.
Buy the way, I originally created it to create .AML persona files but for some reason dragging them to a character in iClone wasn't working. It seemed to load it into the character but for some reason the animations were not showing up????
That's why it only creates .lua files for now because they work and its also why the AML creation coding isn't in the code I listed, I removed it for now. Once I figure out why the .AML files don't work I will be adding an option so we can choose the file type to save as LUA, AML and I think there is a third one I will be adding but can't think what it is at the moment.
For now the only thing we can edit is the name of the animation that shows up under the perform options in the persona.
I will be adding the other things that can be edited also and I will also be adding the ability to create Idle, move and operate options as well.
Also intend to make it possible to add animations from more than 1 file into the persona. That's why it has the tick boxes. It will show all the animations in the folders we list and we can untick the ones we don't want.
Anyway, just a couple of comments for some of my plans for this.
When I add some things I will replace the code in the second post and add a comment stating that an update has been added so you know.
You will then be able to copy the code and create a new file (you might want to keep some of the previous ones I posted???)
I will take notice of requests/suggestions made by people....thanks Rampa, definitely listening
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
5 Years Ago by
Delerna
