glenn_173254
glenn_173254
Posted 2 Weeks Ago
Last Active: 5 days ago
Visits: 10
Hi all, I am not sure if I am on the right place over here. But I am intrigued by the possibilities of CrazyTalk, but now I am a bit puzzled what product I need. Here is what I would like to do:
I would like to create talking faces (based on real faces or virtual ones), that do lipsyncing for instance in the corner of a screen (while doing a software demo for instance). So I suppose I can somehow add a movie behind my faces as well? (in stead of a picture?).
Should I go for the Pro version or the Pipeline (cant really see big differences?) and Should I add the 100 faces as a bundle? (I suppose I have way more hairstyles and stuff If I do that?
Posted 2 Weeks Ago
Posts: 15.3K,
Visits: 23.2K
CrazyTalk 8 can easily create talking heads from photos or drawings. You can also add automatic lip-sync by recording your voice, loading an audio file or by using text to speech. However, CrazyTalk isn't designed for live presentation work which is what you seem to need. In CrazyTalk when you add a voice to your character a voice script has to be created. This only takes a few seconds normally but can't be done "Live" sadly.
glenn_173254
glenn_173254
Posted 2 Weeks Ago
Visits: 10
Oh no, it doesn't have to be live. I was more thinking of doing a screen capture of a software demo, use voice over it and then in stead of my own face in the bottom corner use a "gimmick" face that does the lip syncing.. Is this easy to do?
Posted 2 Weeks Ago
Posts: 15.3K,
Visits: 23.2K
Well, in that case, CrazyTalk 8 should be perfect for you.  You will really only need the Pro version. The Pipeline version is only required if you also plan to send 3D heads to iClone or Character Creator.
glenn_173254
glenn_173254
Posted Last Week
Visits: 10
Thanks! However how do you do this with crazytalk: I want to export the face onto a video I made to put in the bottom corner where the image talks with the video? Or can I add a video behind the face (with audio) in stead of a steady image?
Posted 5 days ago
Posts: 15.3K,
Visits: 23.2K
Unfortunately, video backgrounds are not supported in Crazytalk 8. However, most video editors will allow you to overlay one video over another. So you just need to export from CT8 to your required video format and then use the video editor to overlay the two videos.
