Tony (RL)
Tony (RL)
Visits: 1.7K
Dear iCloners,
If you want to understand "How to Reduce GPU Usage for Iray Renders", please watch the Video Tutorial below or check out Online Manual.
Thank you!
5 Years Ago by
Tony (RL)
charly Rama
charly Rama
Posts: 1.9K,
Visits: 16.8K
really appreciated, thank you
Dan Miller
Dan Miller
Last Active: 3 days ago
Visits: 1.8K
This is helpful thank you. The problem I'm having is iClone 7 is not using the GPU. I have GPU selected in addition to the number of CPU cores, but it is not using the GPU at all. I have the Quadro P5000 with 16GB of unused VRAM. Any ideas on how to get iClone to use this VRAM? I am rendering out the IBL Animation iProject as provided in iClone 7 to see how well it will render. So far its been working on it all night and today and only about 70% done. After watching the video you posted, which was helpful, I changed my viewport setting to minimal which definitely helped. Now if I can use that GPU then the render time would be significantly reduced.
gordryd
gordryd
Last Active: 15 hours ago
Visits: 7.6K
I don't think Quadro is supported
Dan Miller
Dan Miller
Visits: 1.8K
Thank you, someone else mentioned that to me as well recently. I didn't realize that mean't not used but I think that's the deal. Thanks.
firefighter1531
firefighter1531
Visits: 521
I could be wrong but I don't think its your card I have a gtx 1070 and I have the same problem slow renders only uses 15 percent of my gpu with cpu turned of if I use cpu the gpu only uses 7% of card I tried everthing this video above said didn't help but I can go to daz and it renders fast. I did a background render of 50 frames in I clone it took 13 hours and only 60%. it just will not use my card my dedicated gpu has 4 g memory left I have another 12 in shared gpu memory.i have cc3 and iclone on a 860 evo ssd and system runs on a 256 m2 970 evo ssd.
abcliu
abcliu
Visits: 172
I have the same problem, I have NVIDIA RTX 2060 and it uses no more than10% of its capacity.
Posts: 5.0K,
Visits: 15.9K
abcliu (6/29/2020) I have the same problem, I have NVIDIA RTX 2060 and it uses no more than10% of its capacity.10% capacity of what parameter of GPU and how did you measure that?
4 Years Ago by
Last Active: 16 hours ago
Posts: 15.7K,
Visits: 30.5K
The only reliable way is to use GPU-Z to monitor. The usage fluctuates per frame rendered, so an average number doesn't mean anything.
Rob Betz
Rob Betz
Visits: 101
Do you have the GPU checked in the "hardware settings"?
