Loading a prop: useless if the prop already exists or if loaded twice
Posted By RobertoColombo Last Month
RobertoColombo
RobertoColombo
Posted Last Month
Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)
Last Active: 5 hours ago
Posts: 1.6K, Visits: 3.0K
Hi,
I want to ask RL to focus of these 2 lines of codes, taken from the example here: http://wiki.reallusion.com/IC_Python_API:Controlling_A_Simple_Prop
#-- Load Box_001.iProp --#
RLPy.RFileIO.LoadFile(ic_template_path + "//iClone Template//Props//3D Blocks//Box_001.iProp")
#-- Get Prop --#
prop = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, "Box_001")
There is a problem: if the Scene already contains a "Box_001" prop or if simply the Box_001 is loaded two times, there is no way to get the correct object handler because the name of the loaded prop changes.
Perhaps it is possible to grab the object handler via
RLPy.REventCallback.OnAfterFileLoaded event callback, but this, like most of the other APIs, is left undocumented...
IMO, the simple and most effective solution is : RLPy.RFileIO.LoadFile shall return the object handler or None if not successful.
So, pls, RL change this otherwise loading
via API multiple instances of the same prop or also loading a prop which already is in the scene is not feasible
Thanks
  Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO /
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the VB with an HDMI splitter) / DirectX: 12
Last Month by RobertoColombo
The-any-Key
The-any-Key
Posted 2 Weeks Ago
Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)
Posts: 110, Visits: 618
You can grab all props with:
prop_list=RLPy.RScene.GetProps()
Then get the latest one with
latest_inserted_prop=prop_list[-1]
2 Weeks Ago by The-any-Key
RobertoColombo
RobertoColombo
Posted 2 Weeks Ago
Hi Jeff,
thanks.
That's anyway a work-around which I would like to avoid.
The best way (which Luke from Rl had already confirmed, but surprisingly was not in this DEVELOPMENT version) is to simply having LoadFile() returning the object handler or None if the operation is not successful.
  Roberto
My PC:
2 Weeks Ago by RobertoColombo
