Python extension libraries
Posted By RobertoColombo 5 Years Ago
RobertoColombo
RobertoColombo
Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)Distinguished Member (10.2K reputation)
Posts: 1.6K, Visits: 3.0K
Hi,
did anybody manage to install PIP as explained here: http://manual.reallusion.com/iClone/script/python/md_docs__python_extension_libraries.html ?
I found following problems:
1. Updated the system PATH variable as indicated in the doc, adding the path "C:\Program Files\Reallusion\iClone 7\Bin64"
2. Opened the Command prompt
3. I launched iclonepy pointing to the full path to get-pip.py => Command prompt complains for the space in the path!
4. So, I moved to the
C:\Program Files\Reallusion\iClone 7\Bin64 and then launching iclonepy from there, pointing sub-path after Bin64, i.e. scripts\Python\get-pip.py
5. The Python script
get-pip.py starts, donwloads some files, tries to install pip and terminates with an exception
Exception:
Traceback (most recent call last):
  File "D:\Temp\tmpsre17a7t\pip.zip\pip\basecommand.py", line 215, in main
    status = self.run(options, args)
  File "D:\Temp\tmpsre17a7t\pip.zip\pip\commands\install.py", line 342, in run
    prefix=options.prefix_path,
  File "D:\Temp\tmpsre17a7t\pip.zip\pip\req\req_set.py", line 784, in install
    **kwargs
  File "D:\Temp\tmpsre17a7t\pip.zip\pip\req\req_install.py", line 851, in install
    self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
  File "D:\Temp\tmpsre17a7t\pip.zip\pip\req\req_install.py", line 1064, in move_wheel_files
    isolated=self.isolated,
  File "D:\Temp\tmpsre17a7t\pip.zip\pip\wheel.py", line 345, in move_wheel_files
    clobber(source, lib_dir, True)
  File "D:\Temp\tmpsre17a7t\pip.zip\pip\wheel.py", line 316, in clobber
    ensure_dir(destdir)
  File "D:\Temp\tmpsre17a7t\pip.zip\pip\utils\__init__.py", line 83, in ensure_dir
    os.makedirs(path)
  File "C:\Program Files\Reallusion\iClone 7\Bin64\lib\os.py", line 220, in makedirs
    mkdir(name, mode)
PermissionError: [WinError 5] Access is denied: 'C:\\Program Files\\Reallusion\\iClone 7\\Bin64\\Lib\\site-packages\\pip'
Did anyone succeed to install a Python package using the method described by RL ?
Thanks
  Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
5 Years Ago by RobertoColombo
Last Active: 18 minutes ago
Posts: 9.1K, Visits: 21.8K
Yeah, they kind of leave out a step -- you need to do it as admin (so open up an Admin command line).
Then it goes smoothly.
5 Years Ago by Kelleytoons
RobertoColombo
RobertoColombo
Thanks Mike.
Now I succeeded Smile
My PC:
