teto45
teto45
Visits: 56
I try to make new sliders with Blender. First try, Nothing change, just to test: - Create a new project, do whatever with the model.
- Export it as .obj
- Don't touch to the .obj file.
- Modify the model with few sliders.
- Create morph with source (current model) and target (the untouched .obj).
- Profit.
Now try to do things with Blender: - Create a new project, do whatever with the model.
- Export it as .obj
- In Blender, import the .obj (tried this with 2.79 and outstanding 2.8). Keep vertices names, import whole body (see below)
- Do something, export it in .obj, under the same name, see below:
- I tried many things, but whatever I do, when I create the morph, it says that ."Obj file or decryption is corrupted".
What I miss? What is the correct options to export successfully a .obj after edit ?
Thanks if you can help.
Posts: 5.0K,
Visits: 15.9K
Here is the right Blender Import/Export settings https://forum.reallusion.com/FindPost393673.aspx
The-any-Key
The-any-Key
Last Active: 3 Weeks Ago
Visits: 1.9K
These worked for me in Blender: https://forum.reallusion.com/399777/Blender-import-and-export-settings
Posts: 5.0K,
Visits: 15.9K
CC3 sliders making routine is different form making morphs in iClone. Those are not going to work for CC3.
The-any-Key
The-any-Key
Visits: 1.9K
4u2ges (1/15/2019)
CC3 sliders making routine is different form making morphs in iClone. Those are not going to work for CC3. Sorry. Was just thinking about the import and export settings in Blender. But maybe they only work for Clone exported object too. That would however explain why I was not able to create morph sliders in CC with the Blender settings. I assume it would be the same settings for iClone as CC. I thought it was something wrong with the avatar I used. But will try with these other settings.
5 Years Ago by
The-any-Key
teto45
teto45
Visits: 56
Many, many, many thanks, both of you. That helps me a lot ! I didn't try it yet because I'm not at home, but there's no reason that woudn't work. And I searched in the forum but found nothing. If someone from Reallusion is reading this, I think that it's must be in user manual. Edit : Just tried. Worked perfectly. Just great. And thanks again. (and discovered something : you can save as a blend, work on another model, re-open the blend, export as .obj and no problem!)
5 Years Ago by
teto45
The-any-Key
The-any-Key
Visits: 1.9K
The settings did not work for me. Got the error "object or key is corrupted". I did however tested some other settings and found a solution that worked for me. Export from CC3 as obj and import to Blender using: Export back as obj to CC3 as morph slider target:
Posts: 5.0K,
Visits: 15.9K
lol We are obviously doing something different. But here is the only way it works for me (and does not work otherwise):
2 Years Ago by
The-any-Key
The-any-Key
Visits: 1.9K
4u2ges (1/16/2019) lol We are obviously doing something different. But here is the only way it works for me (and does not work otherwise):
We live in a wonderful and consistent world :-) I did however used one of the game base avatars, so it might be that.
5 Years Ago by
The-any-Key
jbiziou
jbiziou
Visits: 85
Very cool thank you for the workflow, Can you also export Morph shapes into blender from Character creator 3 ? so you can animate them there ?
