Python Transition Curve
Posted By videodv 2 Months Ago
videodv
videodv
Posted 2 Months Ago
Veteran Member (724 reputation)Veteran Member (724 reputation)Veteran Member (724 reputation)Veteran Member (724 reputation)Veteran Member (724 reputation)Veteran Member (724 reputation)Veteran Member (724 reputation)Veteran Member (724 reputation)Veteran Member (724 reputation)
Last Active: 3 hours ago
Posts: 164, Visits: 4.1K
Anyone know how to set/change the Transition Curve from Linear to Step for example from Python.
I can see it in the Class list but no idea how to set it?
def RLPy.RKey.SetTransitionType (   self,
eTransitionType
Is it a number a string?
Regards
Chris.
The-any-Key
The-any-Key
Posted 2 Months Ago
Veteran Member (614 reputation)Veteran Member (614 reputation)Veteran Member (614 reputation)Veteran Member (614 reputation)Veteran Member (614 reputation)Veteran Member (614 reputation)Veteran Member (614 reputation)Veteran Member (614 reputation)Veteran Member (614 reputation)
Posts: 131, Visits: 751
Set to one of these I think:
RLPy.ETransitionType_Linear
RLPy.ETransitionType_Step
RLPy.ETransitionType_Ease_Out
RLPy.ETransitionType_Ease_In
RLPy.ETransitionType_Ease_Out_In
RLPy.ETransitionType_Ease_In_Out
RLPy.ETransitionType_Ease_In_Sine
RLPy.ETransitionType_Ease_Out_Sine
RLPy.ETransitionType_Ease_In_Out_Sine
RLPy.ETransitionType_Ease_In_Quad
RLPy.ETransitionType_Ease_Out_Quad
RLPy.ETransitionType_Ease_In_Out_Quad
RLPy.ETransitionType_Ease_In_Cubic
RLPy.ETransitionType_Ease_Out_Cubic
RLPy.ETransitionType_Ease_In_Out_Cubic
RLPy.ETransitionType_Ease_In_Quart
RLPy.ETransitionType_Ease_Out_Quart
RLPy.ETransitionType_Ease_In_Out_Quart
RLPy.ETransitionType_Ease_In_Quint
RLPy.ETransitionType_Ease_Out_Quint
RLPy.ETransitionType_Ease_In_Out_Quint
RLPy.ETransitionType_Ease_In_Expo
RLPy.ETransitionType_Ease_Out_Expo
RLPy.ETransitionType_Ease_In_Out_Expo
RLPy.ETransitionType_Ease_In_Circ
RLPy.ETransitionType_Ease_Out_Circ
RLPy.ETransitionType_Ease_In_Out_Circ
RLPy.ETransitionType_Ease_In_Back
RLPy.ETransitionType_Ease_Out_Back
RLPy.ETransitionType_Ease_In_Out_Back
RLPy.ETransitionType_Ease_In_Elastic
RLPy.ETransitionType_Ease_Out_Elastic
RLPy.ETransitionType_Ease_In_Out_Elastic
RLPy.ETransitionType_Ease_In_Bounce
RLPy.ETransitionType_Ease_Out_Bounce
RLPy.ETransitionType_Ease_In_Out_Bounce
YourKey.SetTransitionType(RLPy.ETransitionType_Step)
2 Months Ago by The-any-Key
videodv
videodv
Posted 2 Months Ago
Thanks The-any-Key
will check those out shortly.
Chris.
videodv
videodv
Posted 2 Months Ago
I am trying to change the step of a matieral from Linier to Step but having no luck yet, this is a cut down piece of code I am using.
import RLPy
#-- Get Prop --#
prop = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, "Ball_000")
#-- Get Material from Prop --#
material_component = prop.GetMaterialComponent()
mesh_list = prop.GetMeshNames()
mesh_name = mesh_list[0]
material_list = material_component.GetMaterialNames(mesh_name)
material_colour = material_list[0]
#-- Add diffuse key --#
material_component.AddDiffuseKey(RLPy.RTime(0), mesh_name, material_colour, RLPy.RRgb.RED) # Turn on Red
material_component.AddDiffuseKey(RLPy.RTime(1000), mesh_name, material_colour, RLPy.RRgb.BLUE) # Turn on Blue
# How to change the material keys from Linier to step ????
# This is not working????
#material_component.SetTransitionType(RLPy.RTime(0), RLPy.ETransitionType_Step, 1.0)
RLPy.RGlobal.Play(RLPy.RTime(0), RLPy.RTime(1000))
This will change a default ball "Ball_000" from red to blue and as you can see it it changes over the one second run (linier) this is what I am trying to change so it will change suddenly "Step".
By the way this is from a "Traffic Light" setup I am working on so really need this change to make it work.
Regards
Chris.
dogged2003
dogged2003
Posted 2 Months Ago
Posts: 384, Visits: 3.9K
Try
material_component.SetTransitionType(RLPy.RTime(1000), RLPy.ETransitionType_Step, 1.0)
My YouTube channel.
The-any-Key
The-any-Key
Posted 2 Months Ago
You need to get the key object you want to change.
Ex:
# Grab transform control from prop
transform = prop.GetControl("Transform")
# Create empty key
key = RLPy.RTransformKey()
# Fill empty key with data at time 0 from prop
transform.GetTransformKey(RLPy.RTime(0), key)
# Set transition for key to step
key.SetTransitionType(RLPy.ETransitionType_Step)
I am however unsure if the key object is referencing back to the original key data. Or if you need to add the key to the prop. But we hope it use referencing.
videodv
videodv
Posted 2 Months Ago
Thanks dogged2003 but that will not work
2 Months Ago by videodv
videodv
videodv
Posted 2 Months Ago
The-any-Key (1/5/2019)
Ex:
# Create empty key
Thanks The-any-Key
That will run without error but it will not change the material settings?
I will look more closley at the documention tonight and try to see why I cannot seem to access the Material Settings to change (unless these are not avaliable yet)
I have of course tried many different ways to try and get this to work but so far without success, keep getting an "Atribute Error"
Many Thanks
Chris.
Posted 2 Months Ago
Distinguished Member (17.0K reputation)Distinguished Member (17.0K reputation)Distinguished Member (17.0K reputation)Distinguished Member (17.0K reputation)Distinguished Member (17.0K reputation)Distinguished Member (17.0K reputation)Distinguished Member (17.0K reputation)Distinguished Member (17.0K reputation)Distinguished Member (17.0K reputation)
Posts: 5.6K, Visits: 11.0K
Chris,
There's a confirmed bug (confirmed by the devs) in GetMeshNames so that GetMaterialNames will not work properly (fails).  If that's your problem don't worry about it -- should be fixed soon.
RobertoColombo
RobertoColombo
Posted 2 Months Ago
Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)
Posts: 1.6K, Visits: 3.0K
The-any-Key (1/4/2019)
etc. etc.
Hi,
pls, where did you find these definitions in the doc ?
I might have missed, but I could not find any of the values in the API doc.
Thanks
  Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO /
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the VB with an HDMI splitter) / DirectX: 12
