Tony (RL)
Tony (RL)
Visits: 1.7K
Dear iCloners,
Some Curve Editor Plugin users have found that their iClone 7.4 sometimes crashes if they didn’t update their Curve Editor to the newest version ( 1.11) when updating their iClone to 7.4. This is due to incompatibility between iClone 7.4 and older Curve Editor Plugin versions (1.1 below). We thank everyone for quickly reporting this issue, and we apologize for any inconvenience this may have caused.
To fix this problem, Reallusion has released a new version of iClone 7.4 (7.4.2426.1) to replace the previous version (7.4.2419.1). So please update your iClone to 7.4.2426.1 in order to prevent any possible crashes. You can get the update via the Reallusion Hub or see the How to Update Guide.
PS: You might see this message box after you update iClone to v7.4.2426.1. This is just a kind reminder to update your Curve Editor Plugin.
Posts: 5.7K,
Visits: 26.4K
So, having updated the updates and patching the patches everything appears to be working.
Rottadamic
Rottadamic
Last Active: 3 days ago
Visits: 981
installed it, and it cracht again when I wanted to render. So mutch for more stability
Tony (RL)
Tony (RL)
Visits: 1.7K
Rottadamic Movies (12/26/2018)
installed it, and it cracht again when I wanted to render. So mutch for more stability Hi Rottadamic Movies,
Have you ever tried to re-install your Curve Editor Plugin again? In other users' cases, this way does help.
Would you be able to mention the crash you faced more?
Thank you!
6 Years Ago by
Tony (RL)
Rottadamic
Rottadamic
Visits: 981
ok, I did that, but it still crach when I want to render, then I open it again, try again, and then it works. So this is going on sinds the update, verry anoing
wildstar
wildstar
Posts: 1.2K,
Visits: 5.1K
now lets wait a patch to fix the patch , i just ending my animation work toport all to unity and rollback to 7.3
wildstar
wildstar
Posts: 1.2K,
Visits: 5.1K
today i start my work with iclone .... after i turn on the pc. and open iclone its uninstable and inusable . ( with my 7.3 project only ) i want know if reallusion gonna make some patch to correct this.. i believe its dont have problems with new projects. so lets start one more day working with tons of restarts and crashs. this is will be the first restart righ now . bye
wildstar
wildstar
Posts: 1.2K,
Visits: 5.1K
i make a test right now. before restart my windows. i open iclone unistable one more time and put a character and a motion clip ( a new project just to test ) and all works ok ( the mouse response inside iclone very slow. all things very slow but the animation is playable. and i can use iclone ( much slow but i can ) for sure when i end this animation work i will rollback to 7.3 ps this 7.3 project is much use extensive of keyframing editing and curve editor .
6 Years Ago by
wildstar
Rottadamic
Rottadamic
Visits: 981
hmm, it also craches when you select everything in the timeline of a charackter and press delete
wildstar
wildstar
Posts: 1.2K,
Visits: 5.1K
situations of crashs...
1 - open a project with one already open ( both from 7.3 ) 2 - open curve editor 3 - use faceware for extensive time. 4 - jogging and editing motion clips on timeline. after crash.. iclone unusable and need windows restart.
