CC3 - Polygon reduction - error message about path and alphanumeric characters
Posted By ursu_lenes 6 Years Ago
CC3 - Polygon reduction - error message about path and alphanumeric...
ursu_lenes
ursu_lenes
Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)Senior Member (264 reputation)
Last Active: 6 Years Ago
Posts: 2, Visits: 26
When I try to do some poligon reduction (no matter what option I choose) the loading buffer gets stuck at 34% and I get this error message:https://forum.reallusion.com/uploads/images/b080f222-227f-4f66-8cf2-ae41.png
For a better picture I attached scren shots of CC 3 Preferences and my system varibles
https://forum.reallusion.com/uploads/images/6c103e70-ebe2-467b-ba42-7849.png
https://forum.reallusion.com/uploads/images/10d9b684-a5aa-42fb-bec4-3a4a.png
I'm really out of solutions ... so ... please help!!
6 Years Ago by ursu_lenes
Last Active: 47 minutes ago
Posts: 8.1K, Visits: 60.6K
Try removing the underscore from the name of your temp. Click on the folder buton to the right of the temp folder location in your preferences, and select a folder for it that does not contains only letters and numbers.
ursu_lenes
ursu_lenes
Done it and no use. I removed the underscore and renamed the folder CC3Temp .. nada. If I try to reduce the polygons with option Bake Texture unthicked, it goes to 39%. Otherwise it goes up to 34% only. I got the same error message even with the initial installation settings (I mean the default temp folder). Any other ideea?
krisovvega
krisovvega
Posts: 1, Visits: 5
I have the same problem and I tried different methods.
By the way, do anybody know how to find logs of character creator 3?
Posts: 22.7K, Visits: 35.7K
ursu_lenes (12/25/2018)
Have you tried choosing a different drive for the Temp folder to eliminate that being the issue?
Also do ensure you clean out all your Temp folders as leftover files can cause problems.
1. Type %Temp% in the Search box and click the %Temp% folder in the search list.
2. This will take you to C:\Users\<YOUR PROFILE NAME>\AppData\Local\Temp.
3. Highlight and delete all the folders and files in the Temp folder (some may remain, this is normal).
4. Go to C:\Windows\Temp
5. Highlight and delete all the folders and files there.
6. Go to N:\CC3Temp
7. Highlight and delete all the folders and files there.
8. Restart your computer.
* NOTE: The Local\Temp folder is a hidden folder and so may not appear. To view hidden files and folders, do the following:
1. Open the Control Panel and select "Appearance & Personalization".
2. Click "Show Hidden File and Folders".
3. On the View tab, under Hidden files and folders, click Show hidden files and folders.
6 Years Ago by Peter (RL)
QUBE8
QUBE8
New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)
Posts: 4, Visits: 141
Hi Did you find any solution for this error
zyadmardini
zyadmardini
New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)New Member (6 reputation)
Posts: 3, Visits: 24
I am having the same error with no luck finding a solution
help please!
Wallart
Wallart
Posts: 2, Visits: 28
krisovvega (12/27/2018)
Once helped. And then the same thing.
5 Years Ago by Wallart
Wallart
Wallart
Peter (RL) (12/28/2018)
6. Go to N:\CC3Temp
ppehrson
ppehrson
Posts: 1, Visits: 8
I have the same problem!
