How to Choose what article of clothing you're importing (Clothes vs Accessories)
Posted By info_464136 Last Year
How to Choose what article of clothing you're importing (Clothes vs...
info_464136
info_464136
Posted Last Year
New Member (93 reputation)New Member (93 reputation)New Member (93 reputation)New Member (93 reputation)New Member (93 reputation)New Member (93 reputation)New Member (93 reputation)New Member (93 reputation)New Member (93 reputation)
Last Active: 4 days ago
Posts: 5, Visits: 31
I've imported a shirt for my character, however CC3 is assigning it as an Accessory, which apparently has different attributes than clothing. I can't transfer weights or conform... How can I tell CC3 that this is a Shirt? I swear I've looked everywhere...
Posted Last Year
Distinguished Member (52.0K reputation)Distinguished Member (52.0K reputation)Distinguished Member (52.0K reputation)Distinguished Member (52.0K reputation)Distinguished Member (52.0K reputation)Distinguished Member (52.0K reputation)Distinguished Member (52.0K reputation)Distinguished Member (52.0K reputation)Distinguished Member (52.0K reputation)
Last Active: 4 hours ago
Posts: 15.9K, Visits: 24.1K
When you use the Create > Cloth, Hair, Acc... option from the Menu Bar, your clothing will initially be an accessory, but will become cloth when you select "Transfer Skin Weights".
So the first question is do you have Character Creator 3 Pipeline? This is required to convert clothing.
If you do, then the Transfer Skin Weights option should be available from the Modify Panel > Attribute panel.
I would advise watching the tutorial below which will take you through the process step by step. If you then still have problems, please let us know at which point in the tutorial you encounter problems, and try to include a screenshot showing the issue so we can what is happening. Thanks.
Character Creator 3 Tutorial - Creating Clothing from OBJ Files
info_464136
info_464136
Posted Last Year
Thanks for the response! Turns out my "transfer skin weights" window pane ended up on my third monitor, which isn't actually visible because it goes to a capture card for streaming! Once I had that window back in the main monitor all was well!
