Clothing issue when imported from DAZ
Posted By marcelj29 6 Years Ago
marcelj29
marcelj29
Veteran Member (660 reputation)Veteran Member (660 reputation)Veteran Member (660 reputation)Veteran Member (660 reputation)Veteran Member (660 reputation)Veteran Member (660 reputation)Veteran Member (660 reputation)Veteran Member (660 reputation)Veteran Member (660 reputation)
Posts: 14, Visits: 402
https://forum.reallusion.com/uploads/images/a596165e-caeb-42b0-adb7-b58b.pngHow do I fix this issue?
animatedbeing
animatedbeing
Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)Veteran Member (853 reputation)
Posts: 114, Visits: 1.7K
When transferring the skin weights, select Lateral Positioning. You will see nodes in the inseam that are assigned the wrong color. Select one of the nodes with the wrong color and click the Selection Tool expand button (diagonal up arrow) to expand the selection as needed. Then select the Right or Left button to correct the node assignment. Note: The buttons are for the character's right and left. Repeat until the nodes are corrected.
When you get the nodes corrected, click apply.
Try to do this the first time you transfer skin weights, with the character in an A position. You can correct it after the object is messed up but it is harder to get the nodes selected.https://forum.reallusion.com/uploads/images/293310a1-8569-45db-9bdc-4d06.png
